Bad ball Joints with no play? - JeepForum.com
post #1 of 4 Old 08-29-2011, 10:45 PM Thread Starter
MojoRisin
Anybody have any idea on this? Any help, I'd be much obliged.
== HERE's THE DEAL ==
Put a 3.5 Rubi lift on about 1.5 years ago. Recently I've been chewing through a pair of BFG's pretty rapidly. The tires are both wearing fairly quickly and evenly on the inside. I tried to get any play (up, down, side, back, forth) in either wheel when they were off the ground and got nothing. It's pretty solid on both sides.
== SOME NOTES ==
Tie rod is adjustable (lift)
LCA's are fine (lift)
Sway links are newer (lift)
Track bar looks okay
Upper control bushing might need replacing
Drag link bushing on the wheel side might need replacing
1) I suspected bad ball joints but cannot get any play in them with the wheel jacked up and prying it up. I put a fair amount of force into it with not even the slightest play.
2) Checked the toe. Center to center front is right on about an 1/8 inch difference to rear.
3) U-joints look pretty solid. Replaced about 2 years ago.
3) Steering is a little loose. Heard something recently though. When turning left I get a cracking or clunking noise. Hoping just the pitman bushing.
== QUESTIONS ==
++ Can bad ball joints chew up tires that fast without noticing any play?
++ Could I have not pushed on it hard enough to notice the play?
++ Can bad upper control arms cause tire wear on the inside that fast?
Thx.
MojoRisin is offline
post #2 of 4 Old 08-29-2011, 11:36 PM
Crispynuggets
Get an alignment, then double check those axle u-joint for the cracking noise.
Crispynuggets is offline
post #3 of 4 Old 09-28-2011, 08:27 PM
imac61
1980 CJ7
u need an alignment and do what they tell u
imac61 is offline
post #4 of 4 Old 09-30-2011, 09:59 AM
herbiehind
bent c's?
herbiehind is offline
ball joint , BFG , control arm , tire wear , u-joints
Tom Woods U-Joints and Centering Ball Redrum8675 Engines & Drivetrain 1 08-06-2010 01:30 AM
how often do ball joints let go? jimaug87 Engines & Drivetrain 3 02-26-2009 09:59 AM
Greases for use on wheel bearings, ball joints, LCAs, chassis - WET climates/terrains CB3 Tires & Wheels 3 03-04-2008 03:22 PM
Ball Joints; 1996 Blazer.. I know, wrong SUV! LimitedTime5.9 General Jeep & Off-Road Equipment 4 04-06-2006 04:51 PM
When to replace ball joints? bigsteve3184 General Jeep & Off-Road Equipment 5 08-23-2003 07:43 AM
