Bad axle shaft? - JeepForum.com
post #1 of 3 Old 11-03-2013, 03:43 PM Thread Starter
98tjsahara
Bad axle shaft?
While cleaning the axle shafts on the 8.8 I'm rebuilding, I came across what looks to be excessive wear on the drivers side rear axle shaft where the shaft bearing rides. I've already replaced the seals and outer bearings with Timken's. I'm guessing at least this one shaft is going to need to be replaced though. Can anyone confirm?
Drivers side rear
passenger side rear
Sold the 98 TJ Sahara. Buying another Jeep soon!
98tjsahara is offline
post #2 of 3 Old 11-04-2013, 05:14 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Looks like junk.
Very common on both Ford and Chevy's. In an attempt to lower manafacturing costs, some sharpie came up with the great idea of using the axle for the inner bearing surface.
They used to make an "axle saver" bearing that spaced the rollers out off the worn surface. This may be a cheap alternative to get another 50K or so out of the existing shaft.
jeepdaddy2000 is offline
post #3 of 3 Old 11-04-2013, 05:32 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Use a repair bearing.
SKF Part # R1563
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
