Back fire - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Back fire
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 07-09-2012, 07:12 AM   #1
ledtheway
Back fire
So I have a 97 wrangler with 121k. It is spiting and sounds like it is back firing thru the carb but I know that there is no carb. It is almost like it has a hiccup. Anyone got any ideas???
ledtheway is offline   Reply With Quote
Unread 07-09-2012, 07:59 AM   #2
Mishimoto
Do you have any codes in it? Does it backfire constantly or just after you let off the gas?
Mishimoto is offline   Reply With Quote
Unread 07-10-2012, 11:29 AM   #3
ledtheway
So I went and hooked it up to the dyno. The read 21. I was told the throttle body censer and the GPS censer. Do you think that could be it? Also he wants to charge me $550 to do both. What do you think???
Unread 07-10-2012, 03:20 PM   #4
Mishimoto
Was it a TPS (throttle positioning sensor) that he said was bad?
Unread 07-10-2012, 03:29 PM   #5
ledtheway
Yes
Unread 07-10-2012, 03:30 PM   #6
ledtheway
Code 21???
Unread 07-11-2012, 07:16 AM   #7
Mishimoto
I'm guessing you have the 4.0 six cylinder?
Unread 07-11-2012, 09:25 AM   #8
ledtheway
Yes.
Unread 07-11-2012, 03:20 PM   #9
Mishimoto
Do you have code 21 from pulling the codes using the key on key off method or do you have a P0121 from a handheld scanner that plugged into your OBDII port?
Also,what do you mean by the GPS sensor?
Unread 07-11-2012, 04:04 PM   #10
ledtheway
I took it to a shop and they plugged it in. The code on there hand held read 21. I am not really sure what the GPS censer is that is just what he told me. I am not sure what it is. I want my jeep fixed lol
Unread 07-12-2012, 07:19 AM   #11
Mishimoto
I'd take it to another shop, and have them scan it. Ask them if they can write down the codes with the cost to fix the issue(s). $550 seems steep for just replacing a throttle positioning sensor (TPS) if that is the only thing wrong.
A handheld scanner for OBII vehicles should give P-codes that are 4 digit, so your 21 has me confused. They should have said it has a P0021 or P0121, etc.
Using the Jeep's computer, you only get 2 digit codes, like a 12, 21 or 55.
