Axle upgrade? - JeepForum.com
post #1 of 8 Old 05-25-2012, 04:54 PM Thread Starter
RussGAmtns
Axle upgrade?
I've got a '10 wrangler sport. Thinking about going with 35x12.5's and 4.88 gears after I do the necessary lift. Stock axles are Dana 44 rear and 35 front. I've had some shops tell me that I will need to upgrade my axles with chromolly shafts. Is this really needed?
RussGAmtns is offline
post #2 of 8 Old 05-25-2012, 05:11 PM
freeskier93
Are those the same shops that said you have a d35 front? There is no d35 front, only d30 or d44. Either way your axles re fine for 35s, but upgrading the shafts wouldn't be a bad idea, depends on what kind of wheeling you do.
freeskier93 is offline
post #3 of 8 Old 05-25-2012, 05:19 PM Thread Starter
RussGAmtns
I still got the paper that was in the window when I bought it. I'm positive it said a 35 front. I'll double check it though. Either way if I do anything anytime soon swap the shafts in the front since it's a smaller axle.
post #4 of 8 Old 05-26-2012, 02:48 PM
scubamc
No need to check the paper in the window. It's a Dana 30. Smaller axle, by number, is not what matters. What matters is the actual size of the axle shafts.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #5 of 8 Old 05-27-2012, 07:58 PM
4xFugi
If you're gonna do 35s, take it from me, I run 35s and do "medium" hard 4xs. You NEED something bomb proof in the back, but that 30 up front is fine. This comes from a guy who learned the hard way out in Moab - twice in the same day! Busted the rear axle twice on the same trail some 12 years ago since I did not have the proper upgraded axles.
So, I would say if you're doing "light"and I mean very light wheeling, then get a stronger shaft with more splines. I went to a Ford 9" with super string Mark Williams 35 spline shafts and they are very affordable.
4xFugi is offline
post #6 of 8 Old 05-31-2012, 08:34 PM Thread Starter
RussGAmtns
I appreciate the input. I've done mechanical work since way before I could drive (legally) and can make anything run fast but haven't done much hands-on with building an off road vehicle up from bone stock. I feel confident that most people on here give a damn about someone else for advice.
post #7 of 8 Old 05-31-2012, 11:26 PM
BleepinJeep
1988 XJ Cherokee
so have you figured out what axles you have?? there is a big difference in a d30, d35, and d44... If you do have a d35, I wouldn't waste your money to upgrade it, just replace it if you are going to try any serious wheeling.
Website -
- The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube -
- Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline
post #8 of 8 Old 06-02-2012, 07:06 AM Thread Starter
RussGAmtns
Yep. It is a d30 front. Not sure where I was getting d35 from other than maybe being burned out from long hours on the road several days at a time. I think I will wait a while till I can dump a good amount of money into my JK. I don't want to go out with a half *** build. I want to do it right the first time around and keep this thing where it will stay reliable out on the trail. I got a pretty good set of metric sized A/T tires that are quite a bit taller than stock. They are roughly 32". I've been pretty rough on this thing off road still with bone stock suspension and have had a lot of fun with it and had no issues.
