axle swap - JeepForum.com
post #1 of 4 Old 03-11-2009, 07:07 PM Thread Starter
tex4431
axle swap
Can anyone tell me if there is a differance in a tj front axle & a xj front axle? I want to swap front axles with an 02 wrangler & a 92 cherkee.
tex4431 is offline
post #2 of 4 Old 03-11-2009, 08:42 PM
Brads_nky_yj
As long as the cherokee axle doesnt have the disconnect system on it you should be fine, and from what I know and have read many TJ owners like this upgrade as its better for them since the Cherokee axle is a High Pinion axle whereas the stock TJ axle is Low Pinion. So yes, if there is no disconnect on the axle you should be fine.
93 YJ - SOLD
Brads_nky_yj is offline
post #3 of 4 Old 03-11-2009, 08:48 PM
mxracer513
My 00 TJ has 3.73 gears and my 92 cherokee had 3.07's
My Dually CJ Restoration
../|,[____],
.i.---L-[]IIII[]-
()_) ()_)-o-)_)
KB3RDF ..... Yellow Jeep Club Member # 513
mxracer513 is offline
post #4 of 4 Old 03-11-2009, 08:58 PM
Brads_nky_yj
Oh yeah might wanna check on the gear ratio, unless you plan on re-gearing both at the same time.
93 YJ - SOLD
CJ7 axle swap jeep6959 Engines & Drivetrain 0 03-08-2008 11:24 PM
axle swap randyheff Engines & Drivetrain 0 02-26-2008 06:37 PM
Axle swap on a YJ DustinM Engines & Drivetrain 2 08-21-2006 07:35 PM
axle swap... BigWaylon General Jeep & Off-Road Equipment 1 05-21-2004 06:39 PM
soa axle swap... I-4 Tires & Wheels 2 04-29-2002 09:50 PM
