Axle shaft U-Joint - JeepForum.com
post #1 of 4 Old 04-07-2013, 09:28 AM Thread Starter
BKilburn
Axle shaft U-Joint
I have a set of fairly new chromoly shafts for Dana 30. One of the u-joints have about 1/16" play between caps. U-joints are fairly new. Could this be caused by the caps not being fully pressed into the shaft? I'd hate to think that u-joints could go bad this quickly
2006 Unlimited, 5.5" Long Arm, 35" MTR's w/ Kevlar
Wheel it like you Stole it!!
BKilburn is offline
post #2 of 4 Old 04-07-2013, 01:31 PM Thread Starter
BKilburn
Pulled the shaft, tapped on the caps a little, problem solved. Apparently they weren't pressed on properly at the factory.
BKilburn is offline
post #3 of 4 Old 04-08-2013, 02:41 PM
LoveHate
make sure all the clips are in and seated in the grooves, if not this will happen again.
Just Enjoying Every Puddle
Built Not Bought #693
LoveHate is offline
post #4 of 4 Old 04-09-2013, 04:42 PM
Evildriver-3
Sounds like a clip is missing
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
