Axel issues... I think... - JeepForum.com
 2Likes
  • 1 Post By biffgnar
  • 1 Post By mukluk
post #1 of 10 Old 09-19-2017, 06:40 PM Thread Starter
TrlBlzn
Can someone ease help figure out what could've leaked here?
It looks like this on both sides where axel tube meets hub.
TrlBlzn is offline
post #2 of 10 Old 09-19-2017, 07:23 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
There are only two possibilities, gear oil or brake fluid. Gear oil is thick and stinks, brake fluid is very light weight and has very little smell.
CJ7-Tim is offline
post #3 of 10 Old 09-19-2017, 07:31 PM Thread Starter
TrlBlzn
I just changed the rotors and break pads a few days ago but I didn't disconnect or bleed the lines.
The lines are dry.
Where else could it have leaked from?
Sent from my VS995 using Tapatalk
TrlBlzn is offline
post #4 of 10 Old 09-19-2017, 08:01 PM
puppybreath
As Tim said, gear oil leaking seal in axle.
puppybreath is offline
post #5 of 10 Old 09-19-2017, 08:29 PM
azzkicker
2007 WK
It could be leaking brake fluid around the caliper pistons, which are not even close to where they had been riding because the new pads are thicker. That would come out on the back of the pad.
It could be the axle seals that are supposed to keep your gear oil in the axle.
If you don't know when it started, I'd assume it's gear oil from tired seals. If it started right after the brake pad replacement, I'd vote brake pistons and replace the calipers. It shouldn't be hard to tell the difference if you can get a drop on your finger. I'd start there.
Oh, and since there's a lot of air moving around down there, sometimes a leak can come from one place, and get blown around, confounding diagnosis.
If you got fluid on your brake pads, I'd replace them again after I was sure I'd fixed the leak and cleaned every bit of residue from the rotors with brake cleaner.
07 WK 5.7 QD2, 4" lift, 33X10" tires, M8000s
ARB twin air,Dual AGM group 49, sliders and skids
azzkicker is offline
post #6 of 10 Old 09-19-2017, 09:14 PM
biffgnar
biffgnar's Avatar
Gear oil and brake fluid look, smell and taste different. Shouldn't be that hard to figure out which one it is.
azzkicker likes this.
biffgnar is online now
post #7 of 10 Old 09-20-2017, 09:17 PM Thread Starter
TrlBlzn
It is the axle seals. Both of them.
Called 4wheel parts, who did my gears, to give em hell but it's covered under their warranty so it's all good.
Thanks for helping me think about the obvious y'all.
TrlBlzn is offline
post #8 of 10 Old 09-21-2017, 02:47 AM
dflewelling
Another thing about brake fluid is that it tastes absolutely horrible. Im not recommending you take a swig, but ive had it get in or near my mouth once and i definitely knew what it was haha. Its much thinner than gear oil, good chance its coming out the piston if its the bore is questionable.
Sent from my SM-G935V using Tapatalk
dflewelling is offline
post #9 of 10 Old 09-21-2017, 06:28 AM Thread Starter
TrlBlzn
That's what I was thinking it was because axle seals don't usually go out at the same time.
I had mechanic shop around the corner check it out. The brakes are perfect.
It's definitely the axle seals.
TrlBlzn is offline
post #10 of 10 Old 09-21-2017, 03:53 PM
mukluk
They do if it was the same person installing both axles and damaging the seals.
TrlBlzn likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
