AX15 tranny swap - NV3550 vs NV4500?? - JeepForum.com
post #1 of 4 Old 01-18-2009, 06:42 AM Thread Starter
ADDICTED2MYTJ
Hi all. Just curious whether anybody has any input...
I have a 98 TJ with an AX15 transmission. The synchronizers are going bad, so I'll be replacing the tranny sometime soon. I was told that both the NV3550 and NV4500 are direct bolt ups. Is that true? Is one better than the other? I was told they were, in fact, both heavier duty trannys. Is that also true?? Any input would be greatly appreciated. Thanks in advance.
ADDICTED2MYTJ is offline
post #2 of 4 Old 01-20-2009, 06:56 AM
75SV1
I have looked at both. I went with the NV3550. It is rated slightly stronger than the AX-15. The bellhousings are the same. With the NV4550, its a much larger and heavier duty trans, you will probably need to cut sheet metal in the tranny tunnel.
Tom
75SV1 is offline
post #3 of 4 Old 01-20-2009, 07:13 AM
tcourdin
tcourdin's Avatar
^What he said. I looked at both but the NV4500 is a big heavy trans, I went with the NV3550 just to keep the weight down. It all depends on how much abuse you are going to give it though, if you're into hardcore crawling get the 4500.
88 Wrangler, Rebuilt I6, NV3550,Atlas 2,B&M Shifter,38/38 Weber, Skyjacker Lift & Nitro Shocks & Stabilizer, Black Diamond Discos, 35 " Regul MT's & Outlaw 2 Alum Wheels, 4.88 Gears, Dana 35 & Super 35 kit & Detroit Soft Locker, Dana 30 & Superior Axles & Detroit Soft Locker & No Disco, SRC Front & Rear Bumpers, SRC Side Armor, Warn XD 9000 I Winch & In Cab Controls, OR Fab Tire & Can Carrier, Rock Hard 4x4 Full Cage, Hood Rack & Hi Lift & AX, Outland Seats, KC & Silverstar.
tcourdin is offline
post #4 of 4 Old 01-20-2009, 12:38 PM Thread Starter
ADDICTED2MYTJ
Thanks for the input! Based on the wheeling I do, I think the 3550 is what I need. Now to find one!
NV3550 SWAP IN AN AX15 YJ Part I tobias94yj Fabrication Shop 16 05-15-2011 06:21 PM
nv4500 replacing ax15... jmsvickers Engines & Drivetrain 0 07-16-2009 04:03 PM
nv4500 swap - chevy or dodge? spazzman215 Engines & Drivetrain 1 03-12-2009 06:12 AM
is ax15 worth rebuilding or upgrade to nv3550? Sandhara Engines & Drivetrain 0 07-15-2008 01:38 PM
ax15 vs nv3500&nv3550 David14Rivera Street Jeep Forum 10 07-12-2007 08:59 AM
