AX15 internal to external throw out bearing swap - JeepForum.com
post #1 of 5 Old 04-29-2011, 04:28 PM Thread Starter
medictanker
Can I just swap out the bell housing and parts or is there more
medictanker is offline
post #2 of 5 Old 04-29-2011, 05:28 PM
eglide72
Just did my '93. You need the external slave bellhousing, external slave cylinder, different fork and bearing, different bearing retainer (it has a long nose for bearing to slide on), and new line between master and slave. Scored my bearing retainer from a dakota in the junk yard for cheap, advanced adapters sells the line kit, and bought the bellhousing on ebay. There is a bunch of threads here that could help you out if you do a search. It's a great upgrade. Oh ya and alot patience to get the top bellhousing bolts out.
eglide72 is offline
post #3 of 5 Old 04-29-2011, 06:26 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Do you have donor information on that Dakota? I'd like to confirm my notes...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #4 of 5 Old 04-29-2011, 07:04 PM
eglide72
I think I read about it here or in JP mag. Dakota ran the ax15 for a number of years, I'm thinking mine came out of a '97. I will think some more and thumb thru some old issues and post again if I come up with it. That was the hardest part to find. It was cheap, but I had to pull it myself. I think $20+/-
eglide72 is offline
post #5 of 5 Old 04-30-2011, 08:39 AM
eglide72
Still can't remember where I got the dakota idea from but this is one of the write ups I used. http://www.jeepforum.com/forum/f12/l...p-pics-965067/
eglide72 is offline
