ax-5 question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > ax-5 question
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 07-24-2009, 05:23 PM   #1
77j20
1977 J-Series Truck
ax-5 question
the ax-5 in my 93 wrangler went out. it broke a clip which went through a set of gears and toasted them. the gears that were damaged are the gear on the input shaft and the one directly below that, which from the diagram i have seen looks to be second gear. my question is this. is it possible to take second gear out and just drive with no second gear. the jeep still drives just makes a god awful grinding noise because of the damaged gears. i really don't have the money right now to rebuild the transmission and buy a new set of gears. for as crappy a transmission as these are they sure do cost a lot to repair or replace.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline   Reply With Quote
