AX-15 Trans noise - JeepForum.com
post #1 of 1 Old 06-28-2013, 09:06 AM Thread Starter
Tj3613
AX-15 Trans noise
I have a 97 tj. I6 with a ax-15 . New clutch and throw out bearing. Trans was making a noise on in neutral and with the clutch pedal out. It's still making the same noise. Any ideas. Input shaft had some play . Could it be the input shaft bearing? Any ideas? Thanks for your help.
Tj3613 is offline
