Ax-15 OR NV3550 manual trans - JeepForum.com
post #1 of 4 Old 10-02-2012, 09:51 PM Thread Starter
Mike_rosati
I have a 97 Tj Sport 4.0 5 speed with the Ax-15 tranny in it, with 80K miles, only shifting problems ive had with it is Reverse is a pain sometimes (which from my understanding is common).
Buddy of mine has an 03 Tj Sport 4.0, 5 speed, with 60K on it but has the NV3550 trans.
anyway i drove his the other day, and his trans seemed A LOT quieter, and quite a bit easier to shift than mine (his shifts like butter, where as mine takes a little push into gear..doesnt take an excessive effort tho), and others have said the same exact thing
so just to start with the basics before i go on a wild goose chase... i changed the fluid in my trans to the recommended grade and weight. no change..
So My question for you guys is
Is his NV3550 a quieter, smoother shifting trans.
or is my AX-15 just a little old and tired causing the harder shift, and the bit of extra noise.
What do you guys think? interested to see because if the NV is better than the AX im considering a swap. if not im just gonna rip the AX apart, see if it needs anything (possible rebuild) then put it back in.
Mike_rosati is offline
post #2 of 4 Old 10-02-2012, 10:00 PM
97wrangler-242
I have the ax15 also and it needs rebuilt or replaced. Few syncs are out. I plan on putting a nv3550 behind my stroker I'm building because they are supposed to hold more power and like you said shift smoother. On your reverse issue, what I've always done when it doesn't want to go in is put pressure on the shifter into reverse and ease off the clutch real slow and as soon as it starts to grab it slips right in. Also at a dead stop, try putting it n 1st before reverse. But at 80k miles if you have no excessive play, grinding, or wining I'd leave it be. If it needs work, I think it would be worth the time to track down a good nv3550 instead of rebuilding the ax15
97wrangler-242 is offline
post #3 of 4 Old 10-02-2012, 10:22 PM Thread Starter
Mike_rosati
ill have to try that with reverse tomorrow! i usually have to ease the clutch but the first to reverse is something ive never heard gotta give it a shot
im dying to find someone with a fresh rebuild on an AX-15 to compare it with a NV3550.
post #4 of 4 Old 10-02-2012, 10:29 PM
97wrangler-242
Not sure your price range for the swap but there's a seller on eBay that has brand new nv3550s for a grand shipped. Not terrible for something with 0 miles on it
ax-15 manual , nv3550 , tranny rebuild , transmission
noise in trans nv3550 littleant Engines & Drivetrain 9 06-04-2012 07:04 PM
VSS for LS1/Manual trans? jhughes2013 Engines & Drivetrain 5 02-21-2012 08:56 PM
manual to automatic trans stuckonstocktj Engines & Drivetrain 2 09-28-2010 11:38 PM
up country with manual trans bbal Street Jeep Forum 1 07-04-2008 11:36 AM
NV3550 Trans Problems Baltz Engines & Drivetrain 0 01-12-2007 12:06 PM
