AW4 problems? Maybe Torque Converter? - JeepForum.com
post #1 of 11 Old 12-08-2012, 04:09 PM Thread Starter
BleepinJeep
1988 XJ Cherokee
Hey guys, Ive been searching but cant seem to find anyone with my same problems.
I haven't driven my jeep in a while and today I started it up and it didn't want to go... it was engaged and revving but felt like there was no torque. I put it in 4 low and it had more torque but still not normal. I finally got it out to the street and it would drive in 2wd but the rpms were much higher than normal and if I came to a hill you can just forget it. had to put it in 4wd and rev it up to 4000rpms to slowly creep up the hill.
The tranny fluid is nice and red, not burnt. The last time I drove the jeep I noticed this happening slightly but only when cold... but it would always go away. Today I got it really warm and still no go.
I'm not sure where to start but am leaning towards the torque converter. Anyone have thoughts or input?
Thanks,
Edit - I just figured out that I have plenty of torque in Reverse. So is it possible that when I put it into drive it's going straight to 3rd or 4th gear? That would explain why I have more torque in 4 low and plenty of torque in Reverse. But I still don't know what the problem is?
Website -
- The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube -
- Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline
post #2 of 11 Old 12-08-2012, 04:52 PM
jnicewan
Does the TC stall at normal RPM? Can you manually shift it down to a lower gear? Anyway is a TC was the problem it should have the same symptoms in Rev as in Fwd. Without more detail it sounds like you might be taking off in a higher gear. Do you have access to a scanner that can read codes? Sounds like its in default mode so maybe the manual shift positions will do something or maybe it could be a problem with the shift solenoids.
jnicewan is offline
post #3 of 11 Old 12-08-2012, 05:53 PM Thread Starter
BleepinJeep
1988 XJ Cherokee
Thanks, Ya just a while ago I figured out I can manually shift it down into first no problem. So what is happening is it must be going straight to 3rd or 4th gear when I put it in drive. I don't have a scanner... It is a 1988 XJ.
Website -
You Tube -
post #4 of 11 Old 12-08-2012, 06:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Up under the dash on the passenger side is an inline fuse. I think it's a yellow wire. Provides power to the TCU. Pull the fuse. I bet it's blown or corroded.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 11 Old 12-08-2012, 08:06 PM Thread Starter
BleepinJeep
1988 XJ Cherokee
thanks, I tried that but it seems to be fine
Website -
You Tube -
post #6 of 11 Old 12-08-2012, 08:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Tried this?
Cruiser’s Trans Plug Refreshing
Over near the transmission dipstick tube are 2 rather large connectors. One is black and the other gray. These 2 connectors carry all the info between TPS, TCU, NSS, speed sensor, and transmission solenoids.
Unplug each one, visually inspect for corrosion or bent pins, spray them out with electrical contact cleaner and plug them back in.
Additionally, if your Jeep is an 87 to 90 Renix, it’s always a good idea to reach up under the glovebox area and unplug the connector to the TCU and spray it out along with the receptacle of the TCU. While you’re there, find the fuse right in that area for the TCU. Remove it and spray out it’s receptacle and clean any corrosion from the fuse.
Revised 9-10-2012
post #7 of 11 Old 12-09-2012, 09:21 AM Thread Starter
BleepinJeep
1988 XJ Cherokee
Tried this?
Cruiserís Trans Plug Refreshing
Additionally, if your Jeep is an 87 to 90 Renix, itís always a good idea to reach up under the glovebox area and unplug the connector to the TCU and spray it out along with the receptacle of the TCU. While youíre there, find the fuse right in that area for the TCU. Remove it and spray out itís receptacle and clean any corrosion from the fuse.
Revised 9-10-2012
No, but I'll give that a try next, thanks!
Website -
You Tube -
post #8 of 11 Old 12-09-2012, 12:43 PM Thread Starter
BleepinJeep
1988 XJ Cherokee
ok, I found a great writeup here: http://www.transonline.com/transdige...ers/index.html
I followed this advice and found a small negative voltage at C10 WITHOUT the brake depressed and more negative voltage when the brake IS depressed. He doesn't mention negative voltage or what to do if there is voltage even without the brake depressed...
Any thoughts?
What is negative voltage anyway??
Website -
You Tube -
post #9 of 11 Old 12-09-2012, 07:51 PM
jnicewan
Thats when you have the meter leads reversed.
jnicewan is offline
post #10 of 11 Old 12-09-2012, 08:24 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Pretty much.
post #11 of 11 Old 12-28-2012, 09:41 PM Thread Starter
BleepinJeep
1988 XJ Cherokee
Well I couldn't figure it out so I replaced the TCU and problem solved...
Website -
You Tube -
