Avenger Supercharger install. - JeepForum.com
post #1 of 81 Old 06-23-2006, 07:32 PM Thread Starter
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
I've got all the parts to start my Avenger install this weekend. Some of the parts I've installed already like the intercooler radiater, water pump, oil return line and hoses. This weekend I'll try to get the whole job done. The main jobs are the blower itself, engine management system and 36 lb.injector/timing programming. If anyone has any helpful hints or questions post em up. It can't be any more difficult than regearing I hope.
Bronco guys watch out!!
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #2 of 81 Old 06-24-2006, 10:03 AM
KnightFire
KnightFire's Avatar
I don't have any tips, but I DO wanna know how it went for you and what other motor mods you have done to your Jeep. Other info, what axles are you running (I assume 30 spline axles with your D44), , are you still on your OEM clutch? I was looking at the Avenger (quite seriously for awhile, but now I've pretty much decided on the Kenne Belle SC setup), but I have concerns about my OEM axles and clutch holding up under another 100HP.
Plus I'd look forward to hearing about your tuning and daily driving with the SC.
Thanks!!!
Patriot Blue 4.0L
Cardinal Red 355CI
Flame Red 5.7L 4x4
Titanium Metallic 4.7L 4x4
KnightFire is offline
post #3 of 81 Old 06-24-2006, 10:21 AM Thread Starter
Reelm n Rubi
Fish fear me
stock D44 axles for now. The power will be used wisely till I can upgrade. Currently no other engine mods (internal). I purchased a Split second 2.5 bar laptop controlled engine management system for tuning.
I got the 36 lb. injectors installed last night and the IAT sensor relocated, this morning I'll plug the manifold holes pull the PS pump and mount the blower assembly.I'm not going to install the Split Sec system till last step. Hopefully by afternoon5-6 pm It'll be ready to idle on the stock computer. Sunday will be devoted to installing and tuning the piggy back computer.
505 Performance PCM
post #4 of 81 Old 06-24-2006, 03:28 PM
highrisetj39.5
Nice man... my buddies got an advenger supercharger and it kicks ***. Hes got stock axles and everything and has no problems. you will be Happy!!
highrisetj39.5 is offline
post #5 of 81 Old 06-24-2006, 07:20 PM Thread Starter
Reelm n Rubi
Fish fear me
Takin a break to watch the OSU Beavers play UNC in the CWS. Go Beavs!!
Got the blower mounted, brackets on, plumbing for oil is done and I'm getting ready to mount the throttle body and fill the Intercooler system. Between soccer and CWS I'm running behind schedule. Hot as hell out today too.
505 Performance PCM
post #6 of 81 Old 06-24-2006, 09:10 PM
alexrule123
alexrule123's Avatar
could we possibly get pics?
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #7 of 81 Old 06-25-2006, 01:03 AM
mud-dog27
yea your killin me i need to see pictures and where does the PS pump go
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
post #8 of 81 Old 06-25-2006, 12:43 PM Thread Starter
Reelm n Rubi
Fish fear me
All the engine components stay in the same location except the throttle body. I'll start taking some pics. Sorry for slacking.
505 Performance PCM
post #9 of 81 Old 06-25-2006, 05:26 PM Thread Starter
Reelm n Rubi
Fish fear me
here's a few pics of the fit. I still have some details to take care of like vacuum lines,vent lines, and cooler hoses to secure. The hood closes fine even with the 1" mm lift.
505 Performance PCM
post #10 of 81 Old 06-26-2006, 04:36 PM
alexrule123
thats looks so sick!!! (i wish i could afford a supercharger )
post #11 of 81 Old 06-29-2006, 10:47 PM
9c1 owner
looking good dude.! hope the rest goes well
-Brett-
1995 DGGM Chevy Caprice LT1 9c1
TB Bypass, TPIS airfoil, CIA SSRI, CIA Stealth Bolt, AIR pump delete, LT4 KM, PCM4LESS, CIA QUAD-1's Headers, R/T cats, Dynomax 2.5 Ultra Flo cat back, Pypes X-pipe, Comp Cams Pro Magnum 1.6 RR and 918 Beehives, Eaton posi w/3.73 gears, CPT race race trans w/ 2800 stall, LE1 heads and cam package, DMH electric exhaust cut-outs, 12-way bonnies, Hotchkis rear control arms, PPM extreme front end kit.
goal: 13.3-12.8 in a 4300 lb car :-D
9c1 owner is offline
post #12 of 81 Old 06-30-2006, 09:49 PM
WalterD
How well is throttle response suppose to be at low speeds? I think you just changed my mind on a V-8 swap.
WalterD is offline
post #13 of 81 Old 07-03-2006, 08:25 AM Thread Starter
Reelm n Rubi
Fish fear me
Been busy killing fish but I'm back on track now with updates to come. I've got a slight blower pully rub on the hood at full throttle, so an adjustment is necessary. I think I might just get a smaller pully .
Another minor issue I had was that the serpantine belt tensioner would pull up and rub against the belt at full throttle. To fix it I just drilled and tapped the stop on the tensioner body and installed an adjustment bolt. Now the belt has a 1/8 of clearance at full stop. Today I'll be working on the Jeep most of the day.
505 Performance PCM
post #14 of 81 Old 07-03-2006, 12:52 PM
BMWZ42003
where did you buy this superchager from?
BMWZ42003 is offline
post #15 of 81 Old 07-04-2006, 03:54 PM Thread Starter
Reelm n Rubi
Fish fear me
Ebay $2000 complete. It's practically brand new. I have the large pully on now and it's putting out 3.5 PSI of boost. Avenger says I can adjust it all the way to 11 PSI. I have my laptop management system wired in now and running so I'll order a couple more pulleys wednesday. I'd like to run 8 PSI for around an estimated 320 HP.
Right now it runs a little rich on the bottom end but I can lean it out with the laptop (with a little help from Splitsec.com). I don't want to start tuning till I have tech support. 3.5 PSI of boost doesn't even give any knock at WOT with 85 octane fuel.
505 Performance PCM
Avenger Supercharger OR RIPP Mods HELP BigD6943 Engines & Drivetrain 0 11-22-2009 05:33 PM
Avenger Supercharger jester116th Engines & Drivetrain 1 07-22-2009 06:47 AM
What components go into a supercharger install? paultyler Engines & Drivetrain 3 02-04-2008 07:46 PM
Supercharger Install seanyb505 Street Jeep Forum 89 09-12-2007 06:35 AM
4.0 Avenger supercharger on ebay suicide Engines & Drivetrain 0 10-08-2006 10:11 AM
