auto/ transfer Which do you run? - JeepForum.com
post #1 of 10 Old 02-22-2003, 01:57 PM Thread Starter
TDanks76
1979 CJ7
for you V8 guys out there. Which auto trannies and transfer cases are you running? i wanna auto for my 350 and might as well go for a new transfer case instead of sticking with the Np231 and buying a $431 adaptor. I would also like to do it with as least adaptors as possible. i wanna an auto because I think its cheaper plus this is going to be a daily driver, call me crazy.
CJ 7, with the good stuff.
TDanks76 is offline
post #2 of 10 Old 02-22-2003, 09:57 PM
CSP
I'm running a TF727 tranny and Dana 300 tcase, but I'm also using an AMC 401, not a Chevy V8.
For the fewest adapters possible you're basically stuck with a GM Th350, TH400, or TH700r4. Any of them will have to be adapted to use your NP231.
CSP is offline
post #3 of 10 Old 02-22-2003, 10:39 PM Thread Starter
TDanks76
1979 CJ7
Well I'm not going to use the Np231. If I'm going to do this swap might as well do it right the first time eh. So what are some trans/transfer cases that will bolt and up and work great in a in jeep that runs off a Chevy 350. Remember Automatics!!!! Too much money to put in a stick I'm kinda on a budget. Don't you have to flip the 300 to make it work in a jeep with the stock D30 axle. (oh yeah I'm keeping the stock front axle.) Whats a transfer case that will work with out fliping. i.e. driver side output for front axle.
TDanks76 is offline
post #4 of 10 Old 02-23-2003, 10:36 AM
CSP
I already mentioned the three auto trannies that will work on the Chevy 350. Take a look at Advance Adapters or Novak Adapters websites for transfer cases that will adapt to those transmissions. Most Chevy transfer cases that are worth a darn are passenger drop, so you're going to want to adapt a drivers drop tcase to the Chevy tranny. Really there aren't that many options for you to pick from, so don't go looking for lots of info. There's always Advance's Atlas tcase, but you better be ready to pony up some serious $$$ for that one.
www.advanceadapters.com
Www.novak-adapt.com
CSP is offline
post #5 of 10 Old 02-23-2003, 01:23 PM Thread Starter
TDanks76
1979 CJ7
Dang, alright so what do I have to look for a Ford Np205 or what? also could I convert a 2wd tranny to work on my jeep?
TDanks76 is offline
post #6 of 10 Old 02-23-2003, 07:58 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You might think about a turbo 400/D18 combo out of an early Wagoneer with a Buick 350. My memory is hazy, but I belive that it was also offered with a D20 transfercase as well. This will be a direct bolt up to your GM motor with the adapters already in place.
jeepdaddy2000 is online now
post #7 of 10 Old 02-23-2003, 08:36 PM Thread Starter
TDanks76
1979 CJ7
Is the 400 a little to long to fit in a YJ.
TDanks76 is offline
post #8 of 10 Old 02-24-2003, 09:39 AM
CSP
Jeepdaddy the T400 with either a D18 or D20 or Quadratrac for that matter won't work for him. He wants a tcase with drivers drop for the front driveshaft. All of those are passenger drop. Also, the T400 behind the Buick won't bolt up to a Chevy 350 as the bellhousing pattern is different.
CSP is offline
post #9 of 10 Old 02-24-2003, 10:53 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I am running a 350ci engine, with TH350 tranny and NP203 T-case .. but I also swapped my front axle to match the passenger-dump of the T-case .. and while I was at it, I put a stronger rear-axle in as well .. and made it all SOA.
If you want to keep your front D30 .. then I would get a 1988 or newer T-case out of an IFS Chevy-truck as they use driver's dump.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #10 of 10 Old 02-25-2003, 12:27 AM
CB89XJ
I'm running a Ford 351W, NP435, and NP205 in my YJ. NP435 has a granny low of 6.69:1. I love it.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
231 or 207 transfer case? fran87yj Engines & Drivetrain 2 10-23-2008 04:19 PM
HELP! Tranny/transfer/auto box? serious problems! PilotWolf Engines & Drivetrain 1 08-01-2008 09:27 PM
Transfer case ID Toddmw Engines & Drivetrain 9 07-19-2007 11:33 PM
Auto tranny/transfer case question DuggerCJ Engines & Drivetrain 0 12-28-2006 05:53 PM
2" BB and auto transfer case lowering. MeGAMoE General Jeep & Off-Road Equipment 3 09-02-2006 04:28 PM
