Aussie Locker Dana 30 - JeepForum.com
post #1 of 20 Old 09-19-2007, 08:11 PM Thread Starter
Dizzle
Hey guys I've heard lots of good things about the Aussie locker. I have an 01 TJ and want to install a locker in the front (dana 30). What are the on road characteristics of the Aussie when driving in 2wd? How well does it lock off road? Is it a good locker for tight trails? How much should I pay for installation if I do get one? Any help with any of these questions would be great. Thanks
Dizzle is offline
post #2 of 20 Old 09-19-2007, 08:25 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
You double posted. I just put an Aussie Locker in my D30, and it works great. It is invisible in 2wd because the command track (I think thats what they call the vacuum disconnect) disengages the right side axle. I took it on the Rubicon 2 weeks ago and it was assume. There was only a slightly tougher problem with steering. But that is true of all lockers.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #3 of 20 Old 09-20-2007, 09:40 AM
Edward777
i think it is a great bang for the buck im getting ready to do it and im convinced...customer service is great and if anything does happen oh well they will replace it. Its a great way to suprise your jeep friends!
Edward777 is offline
post #4 of 20 Old 09-21-2007, 05:06 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
To summarize, you won't even notice the Aussie's (or Lockrite or No-Slip) presence when you're driving in 2wd.
The TJ does not disconnect the passenger-side hub from the axleshaft like the YJ does. Instead, the TJ's transfer case completely disconnects the front driveshaft when in 2wd which keeps the locker from locking up hard enough to notice until you shift into 4x4.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #5 of 20 Old 09-21-2007, 10:17 PM
Mr.B
Mr.B's Avatar
TJs don't have a vacuum disconnect? I didn't know that.
Ham license:
Everyone is Welcome
Mr.B is online now
post #6 of 20 Old 09-30-2007, 05:38 AM
VT2BAD4U
Installed Aussies front and rear. Very easy to install. The grin factor alone is priceless, when you can just walk up and over obsticles that used to a challenge. No noticable added steering problems in tight places that were'nt there before. The rear inner tire sometimes "cherps"or spins on tight turns, but that's not that big of a deal either. Just use less throttle. Sounds like a clacky toy while turning tight, but you'll get use to it. The added benefits far exceed the very minor inconveniences, if you can call them that. Great bang for the buck.
VT2BAD4U is offline
post #7 of 20 Old 10-03-2007, 08:40 AM
H2_RECOVERY
Has anyone here driven it in snow ? How did it do on road in 4wd during a snow storm while turning. Did it really under steer?
H2_RECOVERY is offline
post #8 of 20 Old 10-05-2007, 11:32 AM
Rule303
Just ordered mine a few minutes ago.
Rule303 is offline
post #9 of 20 Old 10-05-2007, 01:36 PM
Jerry Bransford
Administrator
You really don't want to have a front automatic locker installed if you have to drive in 4x4 on snow or ice-covered streets. For those conditions, I'd go with an ARB Air Locker so you can leave the front locker disengaged on slick road surfaces when you have to drive in 4wd.
Getting
post #10 of 20 Old 10-08-2007, 06:19 PM
chutta
It's fun in snow til it gets packed down to ice. I try to get out before the &*%^$ salt trucks.
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #11 of 20 Old 10-15-2007, 07:55 PM
rastadog
rastadog's Avatar
I don't have anything to add about snow but I installed mine 2 weeks ago and just got back from the Jamboree in Murphy NC. All I can say is holy Sh$t!!! It's completely invisible and silent on the road. On the trail it's AWESOME. It's easily the best 250 bucks I've ever spent on the jeep. It was pretty fun to install too...unless your jeep spent a couple of winters in Minnesota - the front axle knuckle thing took a little coercion to come apart.
I also added a Solid diff cover while I had it apart.
jim
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline
post #12 of 20 Old 10-16-2007, 11:58 AM
Broken_Soldier
Ok I was just about to post a thread asking specifically about this. I want to get a front aussie, but icy conditions are a guarantee in OK during winter. So, my question is, why is this not a good idea? What's going on mechanically that rules this out? Is it just that the slippage causes the locker to always be locked even under turning, causing binding in the axle?
Strength and honor.
Broken_Soldier is offline
post #13 of 20 Old 10-16-2007, 01:34 PM
Jerry Bransford
Administrator
Exactly. There is not enough traction on an icy road to help the locker unlock for turns. An automatic's normal mode is locked, it unlocks when one tire starts rotating faster than the other... as the outside tire must do during a turn. If that outside tire slips during the turn as it can on ice, the locker won't unlock and you'll have both tires turning at the same time during the turn... making that turn impossible or at least with a great deal of understeer.
Getting
post #14 of 20 Old 10-16-2007, 02:50 PM
Chris_
I love having the locker in front, but off road I get a plowing effect. It usually happens when I turn sharply, and am traveling up hill. The front tires pull, but don't actually turn until you start moving some. I really noticed this a lot the weekend before last. I would have to make sharp turns on these big rocks, and there were steep ledges on the sides, so I had very little playroom to make the turn before I slipped off the side and went rubber side up. It's not a major issue, and I haven't noticed it much before, but in the circumstances I was in then, I could really tell a difference. On the other hand, had I not been locked, I doubt I would have made it to the position where I had the opportunity to notice this. This is why auto lockers aren't great in the ice.
I suspect this is true for any locker though, but just something I thought I would add.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #15 of 20 Old 10-17-2007, 08:39 AM
Broken_Soldier
Thanks Jerry. Guess I'll get an aussie for the rear and use the ice thing as an excuse to look into getting a rubi axle up front.
Strength and honor.
How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle. CanukYJ Fabrication Shop 107 12-04-2011 07:14 PM
Aussie front locker on dana 30 questions Jenyus425 Engines & Drivetrain 4 10-21-2008 03:51 PM
Just Got my aussie locker.... Edward777 Engines & Drivetrain 3 09-28-2007 07:01 PM
Aussie Locker Dana 30 Dizzle Engines & Drivetrain 2 09-25-2007 05:44 PM
Dana 30 & Lock-Rite or Aussie Locker! pdw General Jeep & Off-Road Equipment 15 06-28-2004 11:41 AM
