aussie install question 97 tj - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > aussie install question 97 tj
TJ Dana 60 - BOLT IN REARRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge Bushings
Unread 11-14-2008, 11:27 AM   #1
slafferty
Im currently regearing and adding a true trac in the rear and an aussie up front. The d35 was easy to get the spider gears out since it has a bolt to hold the center pin in. On d30 there isn't any bolt; I didnt want to go beating on the pin. How do you remove the pin to get the spder gears out? Any help would be greatly appreciated, I've had my jeep in the garage way to long and my Old Man keeps b****in about it.
slafferty is offline   Reply With Quote
Unread 11-14-2008, 12:09 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its a roll pin and you have to pound it through with a punch.
There is a hole on the other side of the carrier.
Wheelin98TJ is offline   Reply With Quote
Unread 11-14-2008, 12:14 PM   #3
Chris98TJ
depending on what gears you have you'll have to pull the carrier and take the ring gear off. i have 4.10's and just did an install tuesday and i had to pull the ring to get the pin out
98 tj sport Aussie locked front and rear 4.10's HPD30 8.8 super short sye cv shaft 4.5 lift johnny joint adj. control arms 36in TSL's gen right hi fenders header exhaust custom rockers Solid axle covers f/r the list goes on
Leading bullet sponge for JF Call of Duty crew
X BOX GT- CHRIS98TJ
Chris98TJ is offline   Reply With Quote
Unread 11-14-2008, 09:55 PM   #4
slafferty
thanks...........
