Auburn ECTED? - JeepForum.com
post #1 of 63 Old 04-06-2006, 10:37 AM Thread Starter
base shakers
Auburn ECTED?
what does everyone think about this locker? Is there any history about this company or style of locker? I have been interested in the eaton elocker, but off-road adventures just had a write up about the auburn ECTED that piqued my interest. thoughts?
'05 LJ, ~4" lift, 35X12.5 Toyos, 16" beadlocks, HPD44, HPD60, 4-speed Atlas, 4.6L stroker
base shakers is offline
post #2 of 63 Old 04-06-2006, 10:45 AM
FlexyTJ
FlexyTJ's Avatar
Auburn has made diffs for quite some time. The ECTED is a relatively new product. It is not a true locker because it still uses the clutches when "locked". And rumor has it that with time, the "locking" capabilities diminish as the clutch packs wear out. Technically it is a very high bias limited slip. Check out the Eaton if you want true E- locking capabilities.
MK Motorsport & Fabrication
FlexyTJ is offline
post #3 of 63 Old 04-06-2006, 10:49 AM Thread Starter
base shakers
i was wondering about the full locking capability using clutches. but according to the graphs on their website it will be 100% locked without a doubt, though i agree that it could wear out eventually. but if it's anything like a regular clutch, the replacement parts are cheap, and i bet the install wouldn't be all that hard. i mean, a stick shift clutch is fully locked when engaged!
post #4 of 63 Old 04-06-2006, 10:55 AM
silvergreentj
silvergreentj's Avatar
it should be easy on the pocketbook to replace the worn out clutch packs, i agree with flexy tj, its just another fancy limited slip, we all know about the trac-loc and how easy the clutch packs where out...its about having to take apart your carrier everytime a clutch wears out. same with my quic-lock upfront, once the springs where out i have replacements, the only problem is time
go e-locker, i know someone is going to say screw that, there are shorts, but then they say air locker, but the lines can tear or burn, then ox-locker, but i've seen cables not function or rip, so i guess anyway you look at it, do whats best for YOU!
Slow Life-02TJ-35 Trepadors
98TJ-33 Mtzs
Low Life-87 slammed e30
silvergreentj is offline
post #5 of 63 Old 04-06-2006, 11:09 AM Thread Starter
base shakers
i am thinking about an electric locker. i know there are upsides and downsides to this choice, but i think it is the best for me! i read this somewhere...
"The Eaton locks up by stopping the DS spider gear with steel pins that lock the spider rotation to the ring gear. The drivers side spider gear than has to transfer ALL the torque by turning the DS shaft in it and transfer torque via it's teeth to the PS drive shaft. Looks like the DS spider gear could be put under tremendous stress." ...so people have had gear teeth break. would the ECTED be any stronger? how often do the clutch packs wear out in the trac-loc?
post #6 of 63 Old 04-06-2006, 11:10 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I agree with what the other have said about the ECTED. Its not a locker and Auburn never referres to it as one. It can slip even in the fully locked mode. Just talk to someone who has used one and they'll tell you this.
As for rebuilding the diff, you can just send it in and pay $125 and they'll send you a rebuilt diff in return. Its a nice service, but not very practical or convenient for most people.
I've been running an Eaton E-Locker for over 2 yrs now and it has worked perfectly. I highly recommend it to anyone looking for a selectable locker.
Wheelin98TJ is offline
post #7 of 63 Old 04-06-2006, 11:33 AM
geauxturbo
geauxturbo's Avatar
That is DS side gear not spider gear. I assume they make that thang out of a little better metal than the stock ones.
'97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2
geauxturbo is offline
post #8 of 63 Old 06-18-2006, 12:38 PM
kenskis
I'm confused. I've read: "The Auburn Gear Ected uses a switch operated electromagnetic ring retained under one of the bearing caps inside the differential housing. The ring activates a pilot cone that causes bearing balls to ramp up against the side gear and lock up the differential."
and
"When activated, the current to the coil creates a magnetic field which pulls the cone into frictional engagement with the differential case. The frictional torque created by the cone casues the balls to ride up the ramp machined into the side gear. The lateral movement of the side gear applies a force onto the center block. That load is transmitted from the block to the opposite side gear, compressing the clutch pack."
So it sounds like it truely locks, but will the locking feature wear out, or will just the LSD feature wear out?
It sounds similar to the Elocker which has been described as:
"The Eaton ELocker uses a switch operated electromagnet to create friction with an armature, forcing ball bearings to ramp up and push locking pins into the back of a side gear, locking the differential."
So isn't the ECTED the same basic thing as the Elocker, but with electronic LSD feature?
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #9 of 63 Old 06-18-2006, 02:35 PM
Oman Jeep
Oman Jeep's Avatar
The puzzling thing I've read is that the ECTED is supposed to be "infinitely variable" - and there is a relationship between the voltage supplied and the LSD percentage.
If that's the case - I'd quite like to have a rotary dial rather than an on-off switch.
Oman Jeep is offline
post #10 of 63 Old 06-18-2006, 03:34 PM
trailraider
Can never leave anything alone can you?
1998 Sport, Optima, Nth Degree Tummy Tucker and PIAA 520's
trailraider is offline
post #11 of 63 Old 06-18-2006, 04:46 PM
kenskis
Originally Posted by KC2OTE
in my buddy's Ranger he has a knob that allow him to adjust how limited the limited slip is.
Found that quote in a "Auburn ECTED" thread. I wonder if it's like that in a Wrangler, which has a different computer system, no ABS etc. My main concern is that the locking mechanism relies on clutches, and could wear out. I can't find a definitive answer. There seems to be a grey area between what the LSD part relies on, and what the locker part relies on.
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
kenskis is offline
post #12 of 63 Old 06-18-2006, 05:30 PM
TJZep
I have these in both diffs. Granted, i DO NOT see rocks very often. I use my lockers very sparingly when going up (or down) loose packed hills in trails. It does not rely on the clutches to lock it. it uses an electromagnet to pull a cone/bearing setup together to spool it. The clutches only see real use when open, due to it being a lsd when off. I guess it is not as reliable as a good old detroit for crawling, but there are some good advantages
1. For those of us who want a selectable locker, daily drivers who see wheelin every so often(jeeps are great because they are just as fun to cruise in, top down, lookin down at super dutys!)
2. they are a selectable locker at 550$!!!!!!! not 700-900 + cables or stupid useless compressors that die if u use them for tools or airing up/down
3. the lsds really are nice in winter, rain. No more fishtailing on acceleration at lights
4. Believe it or not, there are those of us who do all their wheeling on our dana 35's (i have 33's and dont want/need bigger tires) I do not think they make an E-locker for the 35(I MAY be wrong, but I looked first) My super35 kit in my yj lasted 3 years, and i like the skinny pedal(in my 4cyl) No probs.
NOW...I admit I only have had them a couple months, and they have seen limited use. we shall see what time will tell, but for now i love them. I think they are good option for those of us running smaller setups who do minor wheeling. If I had moab type places to wheel(I'm in CT) I would probably have a D60 with 513s and ox lockers or arb, running on 35's or bigger, but my 2.5 tj with 488s on 33's is a perfectly capable weekend wheeler. Plus it is just fun to drive!!
Just my honest opinion, from someone who owns the product.
97 tj, 33's and a 4 inch lift, locked front and back, 4 banger and proud of it!
Low Output 4 Cylinder Jeep Club Member # 42
TJZep is offline
post #13 of 63 Old 06-18-2006, 05:34 PM
TJZep
As far as I know they are very close to the same thing. They just started making them for the jeep axles(d44/35/30) so they are not tested. People always hate new products, especially when they trust what they have used. remeber when the first tjs rolled off the line? I had friends that said "who wants to wheel on coils??) Nuff said.
TJZep is offline
post #14 of 63 Old 06-18-2006, 08:06 PM
Oman Jeep
Oman Jeep's Avatar
Nope
I probably won't attempt to integrate it with traction control and automatically detect wheel slip to increase the locker... but it's possible
I'll be happy with a little dial I can turn though... and I can make it all pretty like the Landrovers with a little icons for street, rain, sand, mud and rocks
post #15 of 63 Old 06-19-2006, 06:17 PM
hvac59
hvac59's Avatar
The design concept is a novel one and I like it a lot. It does have inherant maintenance requirements, such as clutch life. Some act as though pulling a carrier assembly is like having a double root canal ! To the point though, why would a ARB, E-Locker, etc...... be better in regards to having lees maintenance ? Thats one I have'nt quite figured out yet. Not nocking their products whatsoever, by no means. Just first hand experiance with the later products has shown that there is not a 100% engagementdisengagement factor in all conditions. Not a big deal, but ECTED's design does not depend on alignment of mechanical dogs or pins to bias. Thats my soap box on this design and I would very much like to try it knowing full well that it's going to a) need ten amps per axle b)require clutch pack replacements c) slip at torque loads that are typically higher than stresses I put on my rig and if it does slip, at least it probally won't pop an axle.
hvac59
White 01 WJ (stock 4.7 limited)
White 08 MK Patriot (minor mods) -SOLD-
Looking for a White (ultralite?) project Jeep -FOUND-
White 09 JK "X"
hvac59 is offline
Auburn Ected Question jeepin man99 General Jeep & Off-Road Equipment 0 11-06-2008 07:25 PM
Auburn Ected help!!!!! john6612 Engines & Drivetrain 0 02-20-2007 10:37 PM
Auburn ECTED noodlestsc General Jeep & Off-Road Equipment 2 01-19-2007 07:40 PM
Auburn ECTED jayr General Jeep & Off-Road Equipment 5 06-22-2006 05:10 PM
Auburn Ected MSHarnett General Jeep & Off-Road Equipment 3 10-08-2004 08:01 AM
