| Wild Boar Products Cargo Rack or Front Bumper Giveaway |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Search Members |
Thread Tools |
| #1 | |||
Registered User | ATTN Ford 8.8 Guys: Pinion Seal Replacement
__________________ '97 TJ Sport :Titan 4.7L STROKER:RSG AX-15 "Terminator":Accel 30lb/hr injectors:2000 intake manifold:HP Dana 30 & Ford 8.8 w/ stock LSD & 4.11s for now:RE 4.5" SF :OME Shocks:AA SYE & Dana CV shaft: MAXXIS Bighorn MTs 33x12.5R15:SRC Front & rear bumpers w/ tire carrier:Cragar Series 320 15x8s:WARN SDB-210HBs:KC slimlites Long & Fog:Bestop Replace-a-top : No Cat and Flowmaster Super 44 Offroad | ||
| #2 | |
Registered User | same thing is happening to me. is the fluid like a milky grey color? __________________ WHITE JEEP CLUB MEMBER #81 1992 Jeep Cherokee 4.5 RC|Ford 8.8 Rear|Front and Rear Discs|33" BFG's M/T 2 12" MTX Thunders |
| #3 | |
Web Wheeler | That's a crush sleeve pinion so you're supposed to check the pinion rotating torque with an in. lb. torque wrench befor you loosen and remove the old nut. When you replace the seal, use a new nut and preload the pinion to the previous reading plus 5 in. lbs. |
| #4 | |
Registered User | Since it sounds like you've lost a good amount of fluid (thus the noise I'm guessing) be sure to use Diff oil with the proper clutch-type LSD addative when you refill it if you have an LSD-equipped 8.8 |
| #5 | |
Registered User | When the seal on my 8.8 went bad, when I drained the fluid it was a milky gray color. I guess from contamination? ![]() As 80cj said, get the the torque inch/lbs readings before loosing the pinion nut. The other option is to mark the nut/bolt & write down the number of turns it takes to removed the nut. I think the inch/lbs readings should be 8-14 inch/lbs if you're reusing the pinion bearings and 16-28 inch/lbs for new bearings. When you go to replace the seal, I put a small amount of gray RTV on the back of it to help seal it to the housing and prevent leaks. Also, if you're reusing the pinion nut, I usually put on a small amount of red loctite to help keep it from backing off. FWIW, when I rebuilt my 8.8 I got new pinion nut and a crush sleeve elminator from summit. I bought new crush sleeves, but was never able to get them to "crush" and get the preload. Ratech 1502 - Ratech Differential Pinion Nuts - Overview - SummitRacing.com - Pinion nut Ratech 4105 - Ratech Pinion Bearing Spacers - Overview - SummitRacing.com - 8.8 crush sleeve elminator. __________________ Few men during their lifetime comes anywhere near exhausting the resources dwelling within them. There are deep wells of strength that are never used. -Richard E. Byrd |
| #6 | ||
Registered User | Quote:
I marked it and went slightly past my mark since the pinion had some play when i lined them back up. Just kinda guessed since I don't have an in*lb torque wrench and I couldn't even use my ft*lb because my brother who brought me the tools (I'm at college 45 min from home) forgot the right adapter. Its not leaking any more and there is no play in it either. I just hope I didn't get it too tight. __________________ '97 TJ Sport :Titan 4.7L STROKER:RSG AX-15 "Terminator":Accel 30lb/hr injectors:2000 intake manifold:HP Dana 30 & Ford 8.8 w/ stock LSD & 4.11s for now:RE 4.5" SF :OME Shocks:AA SYE & Dana CV shaft: MAXXIS Bighorn MTs 33x12.5R15:SRC Front & rear bumpers w/ tire carrier:Cragar Series 320 15x8s:WARN SDB-210HBs:KC slimlites Long & Fog:Bestop Replace-a-top : No Cat and Flowmaster Super 44 Offroad | |
| #7 | ||
Good luck, keep us posted. ![]() | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Dana 23 pinion oil seal replacement help | timr51 | Engines & Drivetrain | 0 | 10-24-2009 08:20 PM |
| need help with ford 9in pinion!!!!! | Jenyus425 | Engines & Drivetrain | 0 | 05-10-2008 02:19 AM |
| Changing Pinion Seal D30 - D44 | EHUPP01 | Engines & Drivetrain | 0 | 02-18-2008 07:38 PM |
| Rear pinion seal replacement | jzhawk | Engines & Drivetrain | 0 | 12-20-2006 02:30 PM |
| D44 Pinion Seal | Gerg | Engines & Drivetrain | 0 | 07-03-2006 03:36 PM |
Previous Thread
Next Thread
