ARB Locker- Oil w/ friction modifier in it? - JeepForum.com
post #1 of 2 Old 01-27-2014, 08:44 PM Thread Starter
Tuffjeeper
I just changed gear oil in my TJ. When adding oil back to it, I took a 1/2 used bottle of oil with friction modifier added to it, and threw it in the diff with the rest of the standard oil (no friction modifier in it). I pulled it out of the garage and parked it then thought nothing of it. Literally drove it 20-25 feet and parked it.
After researching today, my studying has shown that ARB recommends that I use regular gear oil, and to NOT use an oil with a friction modifier. Because of this, I will be changing the diff oil. (Probably borderline OCD, but it is what it is)
My question is: is it worth my time to take everything apart and clean the entire axle out for 1/2qt of friction modified gear oil? Should I just drain it, and put in the correct oil?
Opinions? Thoughts?
Thanks
Originally Posted by plrbear View Post
Destroyed it somehow..... It went wobble wobble wobble boom
Tuffjeeper is offline
post #2 of 2 Old 01-29-2014, 08:55 AM
Evildriver-3
I have done many ARB's and even repaired quite a few from instal mistakes, i don't see why you would have to run out and drop the oil.
There is no need for friction modifiers, but it still should have a good hypoid type gear oil.
Unless something about the friction modifier make up attacks the seal or o-ring of the ARB i wouldn't worry about it
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
