Anyone use an engine lift plate with a leveler to pull an engine? - JeepForum.com
post #1 of 3 Old 08-04-2008, 12:58 PM Thread Starter
tankcj
tankcj's Avatar
I'm pulling a 304 out of my CJ and then installing a 401... and I want to use an engine lift plate (mounts to the intake manifold using the carb studs) and I also have a leveler...anyone use this combo?...any problems or things I should be aware of? Seems kind of 'unnatural' to have the leveler chains angling in towards the center of the motor instead of each corner of the manifold/head. I want to use the lift plate because I plan on assembling the engine completely before dropping it in and with all the hoses, brackets, lines, etc, the outboard intake bolts are either covered or the chain that would attach to them is gonna hit something.
2011 2dr Rubicon Auto, AEV 3.5" Premium, PSC Brawler Lite front bumper and skid, Evap skid, Raceline Monster beadlocks, 35" KM2s, 5.13 gears, Trailgater, Expedition One rear Bumper and Tire Carrier, ACE Rock Sliders, Warn Powerplant, ORW trans cooler
tankcj is offline
post #2 of 3 Old 08-04-2008, 02:38 PM
NOGO
2005 KJ Liberty
I have used the plate and leveler before without any issues. Its very straight-forward.
NOGO is offline
post #3 of 3 Old 08-06-2008, 02:29 PM
danholovic
I've done it too. In my case I made my own manifold plate by using 3/16" x 2" angle and 1/4" plate drilled for the carb studs. I did that because of what you mentioned - by extending the angle out past the carb flange a ways, the chains from the leveler are closer to straight down. Used grade 8 bolts to attach the thing to the manifold.
Building it like that isn't really necessary, but I got a new welder and had some steel, so I just HAD to do something with it.
danholovic is offline
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 17 11-29-2016 07:24 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 07:01 PM
Engine/trans skid plate ? Gonewhln Fabrication Shop 1 01-19-2009 11:05 AM
help with 4.0 YJ engine pull andychrysler Engines & Drivetrain 2 07-28-2008 08:44 PM
steering box skid plate, rocker panel, engine skid plate base shakers Fabrication Shop 2 07-27-2005 11:49 AM
