Is anyone running propane? - JeepForum.com
post #1 of 10 Old 12-21-2004, 06:17 PM Thread Starter
rhino1
I want to run propane on my CJ. I will be running a 350 with around 11:1 compression, I understand that propane burns at 110 octane. Has anyone done this conversion? I have read about junkyard swaps and new parts out of the magazines. Whats up with this project?
rhino1 is offline
post #2 of 10 Old 12-29-2004, 04:09 PM
wes19d
Sorry for my ignorance but I have always believed that propane was only used for desiel engines. If I am incorrect please feel free to educate me.
Wes
05 RUBI
wes19d is offline
post #3 of 10 Old 12-29-2004, 06:23 PM
Mr_Munt
Don't waste your time or money, My family has been in the propane business for 65 years and you will not be happy, we don't even run propane in our trucks anymore due to the lack of power and crappy starting when it get cold. I could go on and on but won't bore you, Just don't do it.
Mr_Munt is offline
post #4 of 10 Old 12-31-2004, 08:13 AM Thread Starter
rhino1
thanks, but yes you can run propane instead of gas, you just have to replace the carb and get a few extra parts.
rhino1 is offline
post #5 of 10 Old 12-31-2004, 08:22 AM
danmc77
What's the advantage of propane? Cheaper? I obviously don't know anything about it either.
danmc77 is offline
post #6 of 10 Old 01-03-2005, 06:05 AM
75SV1
I work at one of the major diesel engine manufactures. I did ask around on converting to CNG and propane a few months back. From my source, with a direct conversion, no internal mods (cam change, C/R bump) you would loose at least 10% of your power if not more. Propane cost as much as gas does in most areas. I think in some regions (Texas and Alberta Canada), it might be cheaper and feasable to convert. Propane has a higher octane rating. So you could increase you compression ratio. This leads into as to why Diesel motors are converted, they already have a high C/R 18:1 and up. They do need a new head though for spark plugs. The reason you see diesels converted to propane is for emmissions. You will mainly find them on commutor busses in big cities.
I did check out CNG, there would have been a savings, but limited infrasturcture where I live. OK and CA have more than a few stations. Still, figure about $200 savings for every 15K of miles. Also at least a 10% loss of HP, and a loss of range.
Tom
75SV1 is offline
post #7 of 10 Old 01-03-2005, 02:34 PM
artsound
Tom
Go join the yahoo strokers group and ask there- some stroker set ups have like a 12:1 CR --So there are deffinatly folks doing it over there
ARTSOUND
1995 XJ ,2x4 / Rusty's intake w kn filter/ Home brew cold air box/99 intake/ 62mm bored out TB/ MSD wires/MSD 6a/MSD blaster coil/Clifford headers/2.5" mandrel bent downpipe/magnaflow hi-flow cat/2.5" mandrel bent catback w/dynomax super turbo muffler/ 3 core xtreme radiator/hi-flow water pump
HD rear springs and daystar budget boost
artsound is offline
post #8 of 10 Old 01-04-2005, 09:41 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The primary advantage with propane is emissions. This is why you see fork lifts and other internial combustion work rigs running propane around indoors. However, for outdoor use, propane preforms poorly.
jeepdaddy2000 is offline
post #9 of 10 Old 01-08-2005, 11:46 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Contact JP magazine for a back issue. Last issue, they had a feature on propane conversion. You might also want to check out these websites www.propanecarbs.com, www.propaneguy.com, and www.alternatefuelsracing.com.
Matt Gertsch is offline
post #10 of 10 Old 01-13-2005, 02:55 AM
JamesH
Over here in England quite a few people run vehicles on propane (or Liquified Petroleum Gas - LPG as it is labelled here). My '98 XJ 4.0l was converted recently and runs fine with only a tiny loss in power ~10%
It's quite common in several european countries -Italy, Netherlands, UK because petrol/gas is 80 pence per litre = $5.70 per gallon and propane/LPG is half the price or less! (In UK anyway.)
I can only speak for my UK experiences and do not know what conversion equipment is available in US. My kit is manufactured by OMVL and other common kits here include Prinz, Iwema & Startech - Sorry I don't have web addresses for the manufacturers to hand.
JamesH is offline
Propane Conversion in a TJ? Maverick906 General Jeep & Off-Road Equipment 28 09-15-2010 10:21 AM
360 on propane Roadymi Engines & Drivetrain 1 01-14-2010 10:35 AM
Conversion of 4.0 to propane? CraigAllen Engines & Drivetrain 0 09-07-2005 01:47 AM
Running on Propane Gator Engines & Drivetrain 5 01-25-2003 11:44 PM
Propane Injected! RobsYJ Engines & Drivetrain 5 10-28-2002 02:12 PM
