Anyone with a Rochester carb? - JeepForum.com
post #1 of 4 Old 05-07-2002, 05:15 PM Thread Starter
Zeke
I read all about putting a Rochester carb on my 258, and I finally got mine. Took a couple of weeks because of the guys at AutoZone.
Anyway, I'm in the process of installing it, and I had a couple questions for anyone who had done it already.
1) I bought a Rochester 2GC because I thought those were manual choke, but mine came with an automatic choke. Were some automatic? Also, can I run the automatic choke?
2) What is that threaded hole at the back of the carb near the bottom, and what should I do with it?
Other than that, it looks good. Just have to work on fabricating a throttle linkage and a choke linkage. Thanks for any help you can give.
Zeke
Zeke is offline
post #2 of 4 Old 05-07-2002, 10:04 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If the choke is an electric one simply connect it to the ignition side of the ignition switch(or through an ignition activated fuse in the fuse box). If it is a heated vacuum style,run a piece of brake line from the choke to the exhaust. Wrap it around the (header)exhaust pipe or manifold and run it back up to the air cleaner(inside the element) via a rubber vacuum hose. This provides the bi metal coil with heat.As for the threated hole,It's an auxiliary vacuum port. Simply plug it with a threated pipe plug and forget about it.
bazinga
jeepdaddy2000 is offline
post #3 of 4 Old 05-08-2002, 06:35 AM Thread Starter
Zeke
Thanks for the advice, it was just what I was looking for.
My choke is a heated vacuum one. I assume I also run a vacuum line from any source of vacuum to the choke, right? There seems to be a place for that to come in. I'm guessing the bigger threaded hole that comes right into the choke is for the heated air and the little nipple right next to the choke is for the vacuum.
Zeke is offline
post #4 of 4 Old 05-08-2002, 09:52 PM
jeepdaddy2000
1971 CJ5
The vacuum comes from the choke housing,simply hook a steel line to the choke port(big threaded hole on choke) and wrap it around the exhaust(which heats the air), and run a rubber hose from the steel line to the air filter.The nipple is probably an aux. vac. port. There are about a billion different configurations of this carb so it is hard to tell,it might help if you can post a picture.
bazinga
Any carb guys? Rochester Quad on the Chevy 305 in my Jeep learfxr Engines & Drivetrain 5 08-12-2009 06:51 PM
Rochester 2GC 2bbl carb on GM 5.7L runs high rpms 3S00W Engines & Drivetrain 25 01-26-2009 05:16 PM
4X4 shop near Rochester, NY FZ1 General Jeep & Off-Road Equipment 3 03-20-2008 08:26 AM
Throttle Linkage (Rochester Carb) Zeke Engines & Drivetrain 3 05-19-2002 11:23 PM
HEI Ignition and Rochester carb mods dpoliver Engines & Drivetrain 5 04-29-2002 05:06 PM
