any V8's with intake? - JeepForum.com
post #1 of 6 Old 03-01-2003, 06:42 PM Thread Starter
EYPUFF
EYPUFF's Avatar
Well i was at the local Autozone again.. and i was at the "offroading" section for a while.. wiped away the drool and found myself in the air filter aisle. i found a k&n one for my jeep but i decided to save myself the couple hundred and decided to "borrow" my friends filter from his honda. we put it on but we get no extra push nor the desired sound... i believe it's because my friends runnin a 4 banger that it has the more effect than my 8. but maybe if i bought the filter designed for the jeep it would have the desired effect.. anyone have done this before.. cuz i want to save my money for some other parts if it doesn't work.. let me know
1995 GC 5.2 Limited V8
Green Jeep Club Member # 32
EYPUFF is offline
post #2 of 6 Old 03-01-2003, 08:46 PM
pHaZe5unIt1
Are you talking about the induction kit or just the filter?... I have the fiter. I didnt spend a couple hundred, more like 59.00. This filter is a lifetime and needs to be "cleaned"(and oiled) every 50,000 miles. I like the k&n filter very much notice a little change(i.e. gas mileage went from 12.5 to 13.8 after install ) A friend of mine but a tornado on his with the k&n and noticed a big change in throttle response.
hope that helps..
Any? pm me(used to work at az..know some stuff about cars)
2004 wrangler 2.4L
pHaZe5unIt1 is offline
post #3 of 6 Old 03-01-2003, 09:01 PM Thread Starter
EYPUFF
EYPUFF's Avatar
Sorry bout the confusion.. but i was talking about the kit being a couple hundred bucks.. but i just wanted to try the filter itself to see if it would have any effect. but yah i'll probably end up buying the k&n filter.. maybe even the tornado.. thanks for the suggestions.. do you know of any bolt ons that would help my throttle response.. i'm trying to go naturally aspirated due to the constant maintenance of the forced induction.. but yah.. any suggestions would help..
EYPUFF is offline
post #4 of 6 Old 03-01-2003, 09:32 PM
pHaZe5unIt1
I might suggest a new exhust system maybe a bigger dia. pipe. Flowtech or other high flow muffler and exhust system...
Don't know if your state has tip sniffer but if it doesnot I would suggest that if your cat starts to go to just ram a pole throught and make your own "high flow" cat
I dont know if these cars have bigger injectors avail. but if you dont care about mpg then I would suggest them.
Maybe a port and polish of the head and intake&exhuast(true hp)
Ram air...will help.
I have alot more suggestions that I dont know if they have avail. for these cars(do to the lack of room in bay)
2004 wrangler 2.4L
post #5 of 6 Old 03-01-2003, 11:00 PM
Swamp Boy
Swamp Boy's Avatar
I have a home made cold air intake and they do make oversize
injectors I have accell 24lb injectors and I am not sure they made
a huge difference because I did to many things at once.
Intake, chip, injectors,and thermostat all at once. Something
made a huge difference. Dont know what , maybe you need it
all to make a difference not sure. I guess that didnt help you at all. Maybe I should shut up.
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #6 of 6 Old 03-02-2003, 06:36 AM
pHaZe5unIt1
I was thinking more along the line of headers, supercharger, and other things like that
2004 wrangler 2.4L
02 WJ Air intake? mrsandman Engines & Drivetrain 1 01-25-2009 12:00 PM
T5 question about v8's aladgie Street Jeep Forum 9 08-25-2006 10:09 PM
Intake Development Free Intake F1sprint Engines & Drivetrain 6 02-13-2006 10:40 AM
who knows about fuel injection on v8's COJAM Engines & Drivetrain 7 10-27-2005 04:44 PM
gas mileage on your v8's WhiteJeepKid Engines & Drivetrain 8 01-30-2004 07:39 AM
