Any Problem with Switching to a 180 Thermostat in a Dodge 5.9L V8? - JeepForum.com
post #1 of 6 Old 05-02-2012, 12:53 PM Thread Starter
DECJ
I've got a swapped-in Dodge Magnum 5.9L V8 engine in my 2000 Jeep TJ and I am about to do the plenum plate upgrade to my factory intake manifold.
While I am doing this work, I plan to replace the thermostat. I could of course just go with the same 195 thermostat that the factory used for this engine, but I have previously heard that a lot of guys have gone with a 180 unit.
I would also like to go with a 180 thermostat, however, I want to make sure that I am not going to get into any unintended consequences from a performance perspective by doing this. For example, if the PCM is looking for the engine to come up to operating temperature, I don't want to get into any potential fuel mixture or advance curve issues with the PCM wrongly interpreting the lower engine operating temp as an indication that the engine hasn't fully warmed up yet.
So, if anyone with either a Dodge Magnum 5.2L or 5.9L has switched to a 180 thermostat, or is otherwise knowledgeable about the way the PCM looks at the engine operating temp (as a function of coolant temp), please let me know if you have had any adverse performance problems or whether this move wouldn't be recommended for some reason.
Thanks in advance,
Don
2000 TJ, Dodge Magnum 5.9L V8/46RE auto, NV-241OR Rock-Trac tcase, Full-Traction LA, SwayLOK, 35" MT/R Kevlars on forged Center Line wheels, ARB's/Superior Super axles, etc.
DECJ is offline
post #2 of 6 Old 05-02-2012, 01:54 PM
LJameson
The problem with going to a cooler thermostat is like you said, the PCM will possibly stay in open loop and not operate as efficiently, dumping more fuel into the engine then it should.
Chrysler designed the engine as a whole unit to run as efficiently as possible with a 195* thermostat. And really, all the thermostat will help with is the minimum operating temperature that the engine will run at. During hot days, it will run at whatever temp your cooling system is capable of keeping it at. IMHO, I'd just stick to the 195* thermostat.
1990 YJ
LJameson is offline
post #3 of 6 Old 05-03-2012, 07:52 AM Thread Starter
DECJ
Yep, you're absolutely right.
Also, here's a comprehensive write-up on the subject on Dodge Forum ... http://dodgeforum.com/forum/2nd-gen-...-and-cons.html
I also received a response from a Dodge service tech on another board I posted to who basically gave a shorter version of the same information that was in the Dodge Forum write-up.
So, since I don't have a tuner/programmer, I am definitely going to stay with a 195 thermostat as I don't need to get even worse fuel mileage.
DECJ is offline
post #4 of 6 Old 05-03-2012, 08:11 AM
comptiger5000
The PCM will still go into closed loop at 180*. It won't hurt anything to run a the 180* stat, other than maybe a small drop in fuel mileage. However, there's no good reason to do it, as the benefits are minimal. Heck, I'm one of the few running a 5.9 with power mods that still has a 195* t-stat in it.
comptiger5000 is offline
post #5 of 6 Old 05-03-2012, 08:32 AM Thread Starter
DECJ
That's good to know as I wasn't sure what the closed loop temperature threshold was.
I get bad enough fuel mileage as it is, so I don't want to add to that . By the way, here's a shot of my 5.9 going into my TJ. It also has a number of power mods as well ...
DECJ is offline
post #6 of 6 Old 05-03-2012, 08:36 AM
comptiger5000
Very nice!
Switching from 33's to 35's do i need to regear mattwillard06 Tires & Wheels 9 10-16-2011 03:52 PM
Switching 5 1/4 to 6x9s my_304_cj7 Audio, CB & Ham Radios, GPS, & Electrical 2 02-25-2011 02:46 AM
Switching Radios - JK to TJ gabbatemarco Audio, CB & Ham Radios, GPS, & Electrical 1 05-27-2010 10:05 AM
Switching Speakers Over...... Cherokeekid88 Audio, CB & Ham Radios, GPS, & Electrical 3 10-26-2008 08:21 AM
Switching engines for a YJ hudelJP Engines & Drivetrain 0 03-21-2007 05:13 PM
