Antifreeze -- Does it ever go bad? - JeepForum.com
post #1 of 17 Old 05-28-2011, 10:26 PM Thread Starter
Cisco93jeepYJ
I found an old container of "Prestone II Winter Antifreeze Summer Coolant" in my garage that looks like it's from the 80s. I'm thinking about pouring it in my Jeep.
Does antifreeze ever go bad?
1997 Wrangler TJ Sahara 4.0L
Cisco93jeepYJ is offline
post #2 of 17 Old 05-28-2011, 10:36 PM
wushaw
Rockin jeep
wushaw's Avatar
I have some vintage 80's antifreeze also that I have been using in various engines that takes green.
wushaw is offline
post #3 of 17 Old 05-28-2011, 10:42 PM Thread Starter
Cisco93jeepYJ
Good too know, thanks. I think I have a coolant leak, so my system has been (mostly) flushed for me!
post #4 of 17 Old 05-29-2011, 03:44 PM
HELLSUNICORN
If its from a sealed container you should be fine
HELLSUNICORN is offline
post #5 of 17 Old 05-29-2011, 03:55 PM
neatocj
1981 CJ5
pour some in your pups bowl...if he acts a bit strange and has a mild case of the no breathers then it is still good....
Seriously though, I've never heard of anti-freeze going "Bad" or expiring.
Your not pushing the limits of your jeep until your on your side, then something breaks and it's time to go home.
'70 Camaro - Almost Done
'81 Cj-5 - SOLD
'06 MegaCab Cummins- Great White
neatocj is offline
post #6 of 17 Old 05-29-2011, 03:58 PM
gonejeepin04220
1995 XJ Cherokee
the antifreeze in my resovior is brown, is that okay??? hahaha
95 xj,5 speed,
5" lift, 33 12.5 dessert dogs
chrysler 8.25,
"my xj is so horny, sometimes im scared itll came right up in a wheelie"
gonejeepin04220 is offline
post #7 of 17 Old 05-30-2011, 07:56 PM
aewalters
1987 XJ Cherokee
Just make sure it's the correct color, green+orange=new motor
Originally Posted by toplessanddirty View Post
There's something about speeding through the woods, getting bogged down in mud holes and lurching over fallen logs that's good for the soul. Time flies when all we can think about are the four tires underneath us and how we are going manage to get through the next obstacle on the trail. We take each challenge as it comes. We get stuck, we get out. We break something, we fix it. We come out dirty, bruised, and exhausted... but we're smiling.
aewalters is offline
post #8 of 17 Old 05-30-2011, 09:46 PM
Demp
But mine is red! The factory filled it with red
Most times you buy it in a green color though so yeah, as long as it's not a really abnormal color such as brown are some tint towards it should be good.
Demp is offline
post #9 of 17 Old 05-31-2011, 02:58 PM
odinseye84
Im curious to know how mixing colors would cause your engine to blow?
odinseye84 is offline
post #10 of 17 Old 05-31-2011, 03:03 PM
g4x4xgeoff
just go universal
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #11 of 17 Old 05-31-2011, 03:29 PM
aewalters
1987 XJ Cherokee
I can't think of the exact chemical names off the top of my head but they have a different chemical makeup and when mixed they react and produce a brown sludge/gell that gums up all of the coolant ports in your engine, not to mention water pump, radiator and coolant lines. If you go to an autoparts store and buy "dexcool"(orange) And what I call traditional (green) just mix the two together and you will see what im talking about. But they also sell universal fluid which does not react with green or orange. Traditional is most commonly yellow, originally designed to be topoff fluid but it has evolved to be used as more than just top off fluid. Why the two kinds? As car manufacturers realized people don't change fluids as often as they should they started to develop a fluid that lasts much longer than the traditional green coolant, thus was born dexcool(orange) a new organic fluid thy could last up to 100,000 miles without being changed. But why not just not run dexcool in every car? Once traditional has been used in a system that system is forever destined to be traditional, not even flushing the system multiple times can render it safe for dexcool. and once green and orange are mixed you have only days to flush your system before the damage is done, not even flushing the system 6 times and refilling with correct fluid will clean out all of the sludge once the two have been mixed for more than a week
post #12 of 17 Old 05-31-2011, 03:30 PM
aewalters
1987 XJ Cherokee
I'm pretty sure red is universal... Haven't seen it before lol
post #13 of 17 Old 05-31-2011, 05:42 PM
chris142
You can test the antifreeze with a test strip. Napa has them. I'd defiantly shake it up before testing and using it. I'm sure that the Silicates have settled to the bottom of the jug.
chris142 is offline
post #14 of 17 Old 06-01-2011, 02:33 AM Thread Starter
Cisco93jeepYJ
Poured it in. Now I have to figure out where my leak is. Any tips on pinpointing coolant leak locations?
post #15 of 17 Old 06-01-2011, 04:20 AM
aewalters
1987 XJ Cherokee
Make sure all hose connections are tight, and check for any places a hose might be contacting metal as that will cause chafing.
05 Rubicon Antifreeze boils kin22kaid Engines & Drivetrain 8 07-05-2010 07:51 PM
RV antifreeze to balance tires....... Eaallred Tires & Wheels 4 02-22-2010 10:14 PM
Disposing of Antifreeze TheDustMan Engines & Drivetrain 9 12-07-2009 01:09 PM
Disposing of Antifreeze (Where?) Rubi22 General Jeep & Off-Road Equipment 10 03-27-2008 10:17 AM
What is the normal pH for antifreeze? jzmtl Engines & Drivetrain 4 05-02-2007 06:42 PM
