Another option but head gasket? - JeepForum.com
post #1 of 11 Old 04-01-2012, 07:46 PM Thread Starter
gmm11
Okay, I have a 2000 wj, 4.0 97xxx miles. it runs great, untill, today. i pulled her in the garage for a front brake swap. finished up. and as i was pulling out it was smoking so bad i couldn't see out of my mirrors. shut it off. very sweet smelling smoke. im guessing antifreeze.
could this be anything else??
gmm11 is offline
post #2 of 11 Old 04-01-2012, 09:57 PM
Freighttrain
Death by Cracked 0331 head?
Freighttrain is offline
post #3 of 11 Old 04-02-2012, 06:46 PM Thread Starter
gmm11
9331?
gmm11 is offline
post #4 of 11 Old 04-02-2012, 07:21 PM
Freighttrain
2000 and 2001 they used a new casting. The casting number was 0331. They were a little thin in the skin and cracked between 3 and 4 leaking coolant into the oil.
post #5 of 11 Old 04-02-2012, 08:20 PM Thread Starter
gmm11
okay.. could this make it smoke so freaking bad? and is this a common problem
gmm11 is offline
post #6 of 11 Old 04-03-2012, 03:45 AM
Freighttrain
Not sure.From my reading usually it leaks coolant on top of the head and into the oil but that doesn't mean the crack couldn't make it behind the valve and leak into the intake or exhaust.Something to look at.But you have something bad wrong.Sweet smelling steam out the tail pipe can only mean one thing.Your vaporizing antifreeze either in the combustion chamber or the exhaust port.The head pretty much has to come off to find the problem.I don't think there is a coolant passage in the intake like some of the older Carbed engines....but don't hold me to that.....
post #7 of 11 Old 04-03-2012, 10:17 AM
muddr1
It should be white smoke if its antifreeze
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #8 of 11 Old 04-03-2012, 10:51 AM
mdm
Farm Wheeler
He didn't say what color the smoke was. There is only three things that will produce smoke out the exhaust.
Fuel, oil, and coolant. The only one that smells sweet is coolant.
It's time to pull the head.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #9 of 11 Old 04-03-2012, 08:35 PM Thread Starter
gmm11
its white smoke, and yes. its time to pull the head.. is there anyway to check for a crack before i pull it?
gmm11 is offline
post #10 of 11 Old 04-05-2012, 01:21 PM Thread Starter
gmm11
okay, so yesterday i put about 40 miles on. at first it smoked.. it didnt quite have time to heat up..drove to work after it cooled from the little trip to the store.. no smoke at all. had no smoke on the ride home from work. what could this be?
gmm11 is offline
post #11 of 11 Old 04-05-2012, 01:26 PM
Superfuman
Id wait a day or two to see if it occurs again. Maybe it was a freak occurrence. It might still be a cracked head and maybe some carbon or engine crap plugged the crack for a while? If it happens again, here's your chance to build a stroker!
2000 TJ - JB Headers FM Super 44. RC 3.25'' on 31s.
Superfuman is offline
Head Gasket Going? 99grndcherokee Engines & Drivetrain 0 11-19-2010 12:41 PM
4.0 head gasket, junk yard head or get mine tanked and decked iamdurkee Engines & Drivetrain 1 11-01-2008 11:12 PM
258 Head Gasket Job BUDGETBEAST Engines & Drivetrain 6 07-30-2007 05:03 AM
Head Gasket Plink Engines & Drivetrain 1 01-08-2005 10:22 AM
