Another gas mileage thread - JeepForum.com
post #1 of 21 Old 02-06-2011, 10:30 PM Thread Starter
98jeepzj
I know theres probably a million threads out there but no-one can have as bad of gas mileage as me. I have a 98 jeep grand cherokee laredo 4.0 motor, 3.5" lift 31x10.5x15 general grabber AT2s. I literally get 9 MPG. How or why is it so low and is there anyway to get better gasmileage besides chipping it?
98jeepzj is offline
post #2 of 21 Old 02-06-2011, 10:54 PM
The_Blacksmith
1993 XJ Cherokee
9mpg per you doing the math, or staring at your overhead consoul which is completely wrong due to bigger tires?
in my 93 GC 4.0 on 2.5'' lift and 31s my overhead read 9 /10 mpg constantly. Was getting considerably more.
Thanks Chris!
The_Blacksmith is offline
post #3 of 21 Old 02-06-2011, 11:12 PM
Ahrnsbrak14
There is a lot you can do to you engine besides a chip to get way better gas milage. here is some of the stuff, get an electric fan, free flowing exhaust(hi flow cat, muff), cold air intake(if you dont go offroading to much), throttle body spacer, change your sparkplugs and wires maybe even your coil. And maybe the easiest of all, make sure your not cruising at 70 mph everywhere you go
Ahrnsbrak14 is offline
post #4 of 21 Old 02-06-2011, 11:37 PM Thread Starter
98jeepzj
I did the math and got 9.3 my overhead said 9.7 so its not far off. I keep the rpms under 2000. And I usually cruise at like 55 to 65. I'm pretty sure my cat is hallow but I'm not sure. Its old and that could noone ever hallowed it out but I know its all messed up. (But no codes)
98jeepzj is offline
post #5 of 21 Old 02-06-2011, 11:46 PM Thread Starter
98jeepzj
I'm pretty plugs and wires. They look pretty new and I doubt it about 2 months ago
98jeepzj is offline
post #6 of 21 Old 02-06-2011, 11:51 PM Thread Starter
98jeepzj
I'm pretty sure it has *
98jeepzj is offline
post #7 of 21 Old 02-06-2011, 11:55 PM
RogueSpear2023
The throttle body spacer does nothing for mileage or power, they do work in a carbed motor, but in EFI they do absolutely nothing, just gimmick to make people spend money, just like the tornado thing for you intake will increase mileage it again does nothing.
CAI will help very little, same with the exhaust both waster more money the get you mileage back.
I would definatly look at giving your Jeep a tune up, plugs wires, if you haven't changed you plugs in the last 50K it's time. After that just driving nice easy on throttle and brake will help more than anything else.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #8 of 21 Old 02-07-2011, 12:37 AM Thread Starter
98jeepzj
Yeah like I said I try to jkeep it under 2000 rpms. I will have to recheck the plugs and wires. Even before the lift I only got 12- 14 MPG so I can't figure out why its so low. And I just hit 100k miles.
Could the cat being all messed up and there being a exhaust leak at the heads and in the muffler be a cause?
98jeepzj is offline
post #9 of 21 Old 02-07-2011, 12:07 PM
Ahrnsbrak14
I used to think the spacer didn't do sh*t but I installed one and it pushed my mpg up from 15-18. Cai and exhaust will do you good. They can give you 2 or 3 mpg each witch ads up fast. And can be cheap to do. You can just simply take out your cants and muff for free for example.
post #10 of 21 Old 02-07-2011, 12:15 PM
The_Blacksmith
1993 XJ Cherokee
you did the math wrong.
the overhead consoul is off by the exact percent the tires are larger than stock.
for reference my overhead consoul was 4 + mpg off from 31s down to 215 70s
your tach and speedo are also off too, for driving reference.
Thanks Chris!
post #11 of 21 Old 02-07-2011, 12:17 PM
The_Blacksmith
1993 XJ Cherokee
http://www.tacomaworld.com/forum/tirecalc.php
type in 215 70 15 as stock and 31 x10.5 15
15.4% difference in diameter
- 13.3% in rpm ect ect
your speedo is off 9.22 mph @60 to the positive side.
Thanks Chris!
post #12 of 21 Old 02-07-2011, 12:51 PM
Ahrnsbrak14
Is that something that is easy to fix? Do you have to by a chip to change that?
post #13 of 21 Old 02-07-2011, 12:58 PM
Ahrnsbrak14
Is that something that is easy to fix? Do you have to by a chip to change that? The rpms and speedo..
post #14 of 21 Old 02-07-2011, 04:59 PM Thread Starter
98jeepzj
its not off, ive driven threw school zones with the how fast you are going signs, its the exact same on the sign as it is on my dash.
98jeepzj is offline
post #15 of 21 Old 02-07-2011, 05:38 PM
Ahrnsbrak14
Well your tires are not huge and supper tready so I'm not surprised.. But double check your math and try investing in a tune up and perhaps an electric fan.
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 09:53 AM
LTB Mileage SkyChi Tires & Wheels 7 10-27-2008 08:10 PM
4.10/4.56 gas mileage? morningwood1429 Engines & Drivetrain 18 02-08-2008 11:17 PM
AT vs/MT mileage? terrible Tires & Wheels 3 04-02-2006 02:00 PM
Gas Mileage dcuballa Engines & Drivetrain 3 04-04-2004 07:07 AM
