AMC 360 water pump ???s - JeepForum.com
post #1 of 5 Old 11-19-2003, 05:22 PM Thread Starter
slickwillie
slickwillie's Avatar
Well, after being away from my CJ for a while, I finally started working on it. I was going to change out the water pump, & when I was cleaning the flange on the front of the motor, I noticed the crack & missing metal at the big lower right bolt hole.
If you haven't noticed by now, I am a TOTAL AMC noob. How do I remove this part? I've looked at it, & I'm lost. I'm also throwing around the idea of pulling it & rebuilding, or possibly replacing the motor. Any thoughts on this?
1983 CJ7 AMC 360, T-5, Dana 300, Dana 30, AMC 20
Warn XD9000i, RE hand throttle, 1" body lift, OBA
slickwillie is offline
post #2 of 5 Old 11-19-2003, 06:18 PM
fuzz401
1978 CJ7
that is the timing cover to get it off you will have to remove the ballencer off the crank then remove the bolts to the cover and the front of the oil pan
were that chunck is missing could be left a lone pull the timing cover reseal the gasket put the cover back on insert some ultra blue into the bolt hole reinstall the water pump were the bolt goes is to the block and that is it sealing up the hole with ultra blue will keep the water out from the bolt
or you can find another timing cover to replace it with if needed i have some spares
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 5 Old 11-20-2003, 10:31 AM Thread Starter
slickwillie
Thanks for the reply. I thought it might be the timing cover, but it looked strange to me. This is my first experience with AMC, so I have a lot to learn.
Does anyone know of any books or manuals specifically covering AMC V8s? Also, when did AMC stop making the 360 & how can I find out what year mine is?
Thanks again
post #4 of 5 Old 11-22-2003, 07:51 AM
jeepsr4ever
jeepsr4ever's Avatar
Location: near wisconsin north of the twin cities minnesota
Looks like you either had cavitation or you placed a ground where it shouldnt have been.......you can have it tig welded. But if you need a good used one look me up
[SIGPIC][/SIGPIC]
I design and build parts for AMC V8 racing engines, street or trail. If you have a specific performance question please PM me I will be glad to give you 100% accurate information.
Big ones line up...little ones get in a group
jeepsr4ever is offline
post #5 of 5 Old 11-22-2003, 07:52 AM
jeepsr4ever
The 360 was made from 1970 to 1990 and sold in the last year of the grand wagoneer 1991....all timing covers are universal with only suttle differences in the casting
[SIGPIC][/SIGPIC]
4.0L Oil Pump question and Water Pump frhrwa Engines & Drivetrain 2 05-28-2009 01:50 PM
4.0 water pump problems NBFarmboy Engines & Drivetrain 0 10-28-2008 02:56 PM
Replacing the water pump......... zzrich Street Jeep Forum 8 06-19-2008 11:53 AM
water pump Krazee Engines & Drivetrain 1 01-20-2007 05:24 AM
water pump Khriscom Engines & Drivetrain 1 12-14-2003 09:50 AM
