Amc 360 Ticking - JeepForum.com
post #1 of 8 Old 08-16-2013, 05:17 PM Thread Starter
phil8825
Amc 360 Ticking
Hey guys,
Got back a freshly rebuilt 360 today, not a happy customer . The engine is ticking loudly on the right side, the tick changes in speed with changes in rpm. Other side seems normal. I'm thinking at the headers. I attached a video for you guys to take a look and chime in.
Any input would be greatly appreciated
http://www.youtube.com/watch?feature...&v=s9riImQQI3g
phil8825 is offline
post #2 of 8 Old 08-16-2013, 05:26 PM Thread Starter
phil8825
I don't have to much know how but to me it sounds like a leak a the headers on the driver side.
phil8825 is offline
post #3 of 8 Old 08-17-2013, 08:47 PM
uberxj92
1992 XJ Cherokee
Definitely exhaust. Cracked header or bad doughnut or header gasket.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #4 of 8 Old 08-17-2013, 09:00 PM Thread Starter
phil8825
Well lets hope that nothing is cracked, the engine was literally just put back together a couple of days ago..
phil8825 is offline
post #5 of 8 Old 08-19-2013, 04:24 PM Thread Starter
phil8825
So, put in a new gasket tightened everything back up. Still have a small leak but much less than before. The improvement in performance and all over all operation of the motor was more significant than I thought it would be. Performance really takes a good hit with a rather large leak.
Also the whole system is significantly less noisy, mind you that a 360 with exhaust and headers is still plenty loud but not people throwing rocks at you loud.
Now that I still have a small leak I suspect that maybe the headers are warped. Besides machining any special type gaskets that may take care of the problem for me?
phil8825 is offline
post #6 of 8 Old 08-19-2013, 08:04 PM
uberxj92
1992 XJ Cherokee
Special gaskets are band aids.
uberxj92 is offline
post #7 of 8 Old 09-06-2013, 06:08 PM Thread Starter
phil8825
I know, but for now Im taking the cheap way out.. Put on some remflex gaskets and they are sealed now.. Did see the problem though when I took a closer look at the headers. On one of the openings the bead is worn causing the leak. Since I have no idea how old those headers are Ill probably get a new set at some point in the future. For know these gaskets do the trick
phil8825 is offline
post #8 of 8 Old 09-06-2013, 08:49 PM
uberxj92
1992 XJ Cherokee
Cool beans
uberxj92 is offline
