AMC 360 swap - JeepForum.com
post #1 of 2 Old 03-22-2009, 10:05 AM Thread Starter
flashfludjr
1981 CJ5
AMC 360 swap
So I have a 1981 cj5. it has a straight six 4.2 that seems to run well but has some smoke coming from the pcv vent on the valve cover when I rev. the motor. I'm thinking this could be a pretty tired motor. I will be doing a compression test soon. but I just want to look at my options. I was thinking putting the AMC 360 in. I have been told it drops right in. just need to change motor mounts and cooling system. would this be my best option? not to big on the I-6. maybe you guys can change my mind. or maybe seal the deal for the 360 swap...
just looking for some opinions on the subject...
flashfludjr is offline
post #2 of 2 Old 03-22-2009, 11:50 AM
cj7guy
I swapped out a 304 for a 360 in a 78 CJ7 and it was a great torquey motor. I did GM TBI conversion at the same time, which was great for cold starts etc.
My swap was even more direct, didn't have to mess with the tranny, mounts, or rad, but I still think it's a great idea.
If you can find a 304 and put some 360 heads on it, I hear those breathe really well.
07 JKU - 6spd - LSD rear
cj7guy is offline
I6 to V8 swap - Direct swap? tawdr77 Engines & Drivetrain 2 01-17-2010 11:35 AM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 09:08 AM
xj DS swap into TJ jboy416 Engines & Drivetrain 2 10-18-2008 12:11 PM
242 to 231 swap newtoxj Engines & Drivetrain 0 12-04-2006 03:48 PM
2.5L to 4.0L swap bluestreak Engines & Drivetrain 3 08-14-2004 03:01 PM
