AMC 360 Intake Manifold gasket w/aluminum intake - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > AMC 360 Intake Manifold gasket w/aluminum intake
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 08-24-2010, 04:38 PM   #1
turbogus
1978 CJ5
Location: Albany~town, Oregon, Oregon my home and for 200 billion slugs
Black Betty (AMC 360) has a seeping oil leak fore and aft at the Edelbrock aluminum intake manifold. Mindful of the hatchet job the P.O. did on other elements of this old CJ I'm dubious.
Back in the days I ran SBC's in my old Malibu I recall that the Edelbrock manifolds would leak terribly unless, when installing one discarded the rear seal and used a bead of Blue RTV in it's place.
1. Is this the nature of Edelbrock manifolds? or just of Chevy small blocks?
Went down to our local NAPA and they pulled a NAPA made by Fel Pro MS96011 intake gasket manifold and this thing had a windage tray incorporated into it. In addition, the specification called for an Edelbrock 7213 to be used with this Fel Pro gasket. Taking the number down and doing a google search I found that the Edelbrock 7231 is just the intake runner manifold gasket.
2. How are these two items incorporated together on the AMC 360?
The more people I meet,
the more I like my dog.
turbogus is offline   Reply With Quote
Unread 08-26-2010, 05:09 PM   #2
turbogus
1978 CJ5
HAH! An Edelbrock techie on the phone said use the Fel Pro gasket and pitch the wall gaskets and use RTV I'm hoping I'm on the right track, but there's still time for opinions as this will be this winter's project.
Unread 08-26-2010, 05:14 PM   #3
frankenjeep
1994 ZJ
I used a all the gaskets and rtv with my rpm.... never had any problems with it. Was in my 69 amx. Had a 401 . Same engine.
I may be drunk, Miss, but in the morning I will be sober and you will still be ugly.
Winston Churchill
Jesus saves..... "yea? So do my rock sliders" F.J.
frankenjeep is offline   Reply With Quote
Unread 12-01-2011, 09:14 PM   #4
Galt
Galt's Avatar
1983 CJ7
What did you end up using and how has the seal held up?
A=A
1983 CJ7 304 V8
1985 CJ7 258 I6
1993 RX7 1.3L Rotary/ GT40R turbo/484 rwhp
2002 F-150 Lariat 5.4L V8
2007 GMC Yukon Denali 6.2L V8
Galt is offline   Reply With Quote
Unread 12-01-2011, 10:54 PM   #5
jnicewan
Most people ditch the end seals, unless the seal has some type of positive retainers to keep it in place (these dont unless something changed). The biggest problem is they dont have bolts going through them or clips holding them in place so they move around or work themselves out. I always use silicone, I recommend "ultra" either gray or black, most silicones will work I guess but I would at least get and ultra type.
jnicewan is offline   Reply With Quote
Unread 12-02-2011, 11:43 PM   #6
hutch1200
Undocumented Pharmacist
hutch1200's Avatar
1979 CJ7
Same/Same
Let it set up for just a few minutes. Seems to work for me.
hutch1200 is offline   Reply With Quote
Unread 12-04-2011, 05:37 PM   #7
turbogus
1978 CJ5
I rather liked the Gaskacinch I used around the water and fuel ports, held the danged aluminum tray in place.
