AMC 304 or chevy 350 - JeepForum.com
post #1 of 2 Old 09-22-2001, 12:26 PM Thread Starter
Brendan
I have an 88YJ with the 258 and Puegot POS. I want more power, preferabbly an 8. I'm only sixteen, so money is a factor, and complexity as well. I will most likely rebuild, and swap the engine myself. Any opinions are appreciated.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 2 Old 09-22-2001, 09:58 PM
CJ junky
You will have to upgrade the transmission also. The puegot are junk and don,t not last with the stock 6 cylinder let alone a v8. Have you considered a chevy 4.3 v6? They have plenty of power and are easy to find. I suggest you take measurements of your trans/transfer case/bellhousing first. Next go to your salvage yard and see if they have a engine/trans/transfer from a chevy s10 4x4. This combination would be a simpler drop in since they use the same transfer case and the transmission is able to handle the power. Also you will have a lighter jeep since the chevy engine is about 150 pounds lighter.JP magazine has a write up about this set up. GOOD LUCK AND KEEP JEEPIN.
CJ junky is offline
chevy 350 jeepin1270 Engines & Drivetrain 4 02-01-2008 09:42 PM
chevy 350 and 36''s grandman97 General Jeep & Off-Road Equipment 8 12-23-2005 02:13 PM
Chevy 305 in my YJ??? Parabola Engines & Drivetrain 2 02-08-2004 03:10 AM
Chevy V-8 jeepthing2000 Engines & Drivetrain 5 06-04-2003 06:02 AM
chevy 350 in a cj7 80cj7 Engines & Drivetrain 1 01-16-2003 02:05 PM
