-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   AMC 304 or chevy 350 (http://www.jeepforum.com/forum/f19/amc-304-chevy-350-a-12948/)
Brendan 09-22-2001 12:26 PM
I have an 88YJ with the 258 and Puegot POS. I want more power, preferabbly an 8. I'm only sixteen, so money is a factor, and complexity as well. I will most likely rebuild, and swap the engine myself. Any opinions are appreciated.
CJ junky 09-22-2001 09:58 PM
You will have to upgrade the transmission also. The puegot are junk and don,t not last with the stock 6 cylinder let alone a v8. Have you considered a chevy 4.3 v6? They have plenty of power and are easy to find. I suggest you take measurements of your trans/transfer case/bellhousing first. Next go to your salvage yard and see if they have a engine/trans/transfer from a chevy s10 4x4. This combination would be a simpler drop in since they use the same transfer case and the transmission is able to handle the power. Also you will have a lighter jeep since the chevy engine is about 150 pounds lighter.JP magazine has a write up about this set up. GOOD LUCK AND KEEP JEEPIN.
The time now is 03:03 PM.
