AMC 232 Rebuild - JeepForum.com
post #1 of 7 Old 11-08-2009, 12:54 PM Thread Starter
shortgoroper
1983 CJ7
AMC 232 Rebuild
I have AMC 232 built in 1971 (casting number 403E24).
What is the difference (other than displacement) between the 232 and 258???
I want to overhaul it and need some advice.
What can I do for a good head upgrade?? Get the head rebuilt or would the 4.0L head converstion work???
As far as a manifold, do them make an aftermarket intake manifold for the AMC 232??? Would the intake manifold for and AMC 258 work???
Thanks
shortgoroper is offline
post #2 of 7 Old 11-10-2009, 08:27 PM Thread Starter
shortgoroper
1983 CJ7
Any ideas?
post #3 of 7 Old 11-23-2009, 11:32 AM
76cj5jake
1976 CJ5
4.0L wont work holes dont match up right. if you want power outta it offenhauser makes a 4 barrel intake for the 258 might work with the 232 or keep it stock and go with the weber carb. i have a 258 with a shaved head dui ignition weber carb and dual outlet headman headers and i could spin 33-13.50s with 3.52 gears and a 3 speed... i also have some parts a motors when it comes to the straight 6
'81 j20 [/SIZE] 360- edelbrock intake and carb- T18- 208tc- dana60/44- 7 in lift-black wagon wheels- 36-12.50 hummer tires
1976 CJ-5 - '83 258 inline 6- rears fliped+new springs- front disc brakes- headman headers- weber carb-bumbers- rocker tubes- full cage- 33-13.50 swamper LTBs on 15x10s- full fiberglass body- welded rear- warn lockouts
76cj5jake is offline
post #4 of 7 Old 11-23-2009, 06:52 PM Thread Starter
shortgoroper
1983 CJ7
Well.. I think I am just going to bore and deck the block, deck the head and get a 3 way angle job, put the money into getting the engine balanced, and putting good parts into it. I have a weber 38 outlaw with a jet pack and headers on it. I just need to get a nice intake to fit that weber on it.
That will be good enough for me.
post #5 of 7 Old 11-26-2009, 09:03 PM
th3t1nm4n
You'll probably find more help on this on an AMC forum:
4.0 Head on a 232 - The AMC Forum - Page 1
th3t1nm4n is offline
post #6 of 7 Old 11-27-2009, 12:10 PM Thread Starter
shortgoroper
1983 CJ7
Awesome follow-up post.. Thanks for referring me over to that site!!!!
post #7 of 7 Old 11-22-2011, 07:00 PM
chooster5000
1981 CJ7
i just found out that my 81 jeep has a 232 in it and i have a 4 barrel intake and a header on mine
1981 jeep cj-7 258 with t-176 4 speed and 31x10.5x15 tires,
1979 jeep cj-5 gone but not forgotten
chooster5000 is offline
258 rebuild CJ007 Engines & Drivetrain 1 06-29-2009 09:46 PM
AX-15 rebuild kit? Captainofiron Engines & Drivetrain 2 03-01-2009 10:07 PM
304 V-8! Rebuild! GoldenEagleGa Engines & Drivetrain 0 02-05-2009 12:32 PM
To Rebuild or Not to Rebuild? dirtbagofva Engines & Drivetrain 2 10-27-2007 05:46 PM
360 rebuild Jermy01 Engines & Drivetrain 1 02-13-2006 10:36 PM
