Are all high pinion D-30's the same? - JeepForum.com
post #1 of 3 Old 04-16-2007, 09:05 PM Thread Starter
93YJfalcon
Will a super 30 kit with ARB locker swap from a High pinion XJ D-30 to a High pinion YJ D-30?
I'm guessing that the only difference is the YJ has a central axle disconnect and the XJ doesn't.
I'd like to polish my YJ 30 and eventually get an XJ 30 housing (with no CAD), truss it, swap in the hardened shafts + locker and put it in the YJ.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #2 of 3 Old 04-17-2007, 09:33 AM
ringpinion.biz
ringpinion.biz's Avatar
dana 30 reverse
Yes they are the same w/ the exception of disco. or non-disco. And some xj's do have discos as well.
JT's Parts & Accessories
Your 4x4 & Differential gurus
866-349-6801
509-888-AXLE
ringpinion.biz is offline
post #3 of 3 Old 04-17-2007, 08:20 PM Thread Starter
93YJfalcon
Thanks. That's what I hoped!
High Pinion Dana 30 JeepX89 Engines & Drivetrain 4 09-10-2009 07:01 PM
How do you do a high pinion set up? Jenyus425 Engines & Drivetrain 1 10-13-2008 06:43 AM
Dana 60 High Pinion jackedupyj Engines & Drivetrain 3 08-25-2006 09:17 AM
High Pinion d30 - why so much stronger then lp? red99tj Engines & Drivetrain 6 02-28-2006 07:20 PM
What is a High Pinion Axle? topfuel83 Engines & Drivetrain 12 02-17-2006 12:23 PM
