Are all dana 44 axels the same - JeepForum.com
post #1 of 11 Old 08-25-2013, 11:15 AM Thread Starter
Wsigalet95
1988 TJ Wrangler
I'm new to working on cars I bought the jeep a few weeks ago after my first car died. I'm looking to lift it and put some 33s on it and while I'm at it I though I'd put some new axels in it. I found a Dana 44 axel on kijiji is there anything I should look for? And when I go to the junk yard to get the 8.8 from a explorer is there anything I need to look for there?
Thanks a lot
Wsigalet95 is offline
post #2 of 11 Old 08-25-2013, 12:31 PM
Evildriver-3
The D-44 for the front i imagine, depends what they're out of, they are all similar as for internals unless it has VL's and then housing width. What does your jeep have in it now HP or LP D-30 at the front.
The 8.8 you need to re-set the perch and the rear shaft should work with just a new joint and the flange yoke from the explorers shaft or you can buy a new flange yoke
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 11 Old 08-25-2013, 04:23 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
My jeeps a stock 1988 yj
And yea the Dana 44 is for the front
post #4 of 11 Old 08-25-2013, 05:37 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
internally....kinda. Newer JK 44's are not the same. need more info other than a 44. is is full width? some ford D44's ('78-'79) Had the spring perches cast into the housing and are not ideal for a swap.
while all similar, there are many variations in what is a Dana 44
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 11 Old 08-25-2013, 05:47 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
Yea I'm waiting for the guy to get back to me about what it's out if and some photos. It's not in my city so I haven't seen it yet
post #6 of 11 Old 08-25-2013, 08:04 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
Ok so this is what the guy said to me
Chevy special camper its a 3/4 ton front axel 8 bolt with 4:10
Don't think it's gonna be what I'm looking for
post #7 of 11 Old 08-25-2013, 09:52 PM
jp360cj
1977 CJ7
No it's not. Chevy axles have the differential on the passenger side. For your YJ, you'll need a driver side drop for your YJ. Can be found in Fords, Dodge, some FSJ. Unless you find one from an Early Bronco (66 to 77) you will have to cut the axle and possibly get a custom shaft to match the 8.8 width. If I went through all that trouble, I would use a Ford HP44 (Only reason I didn't on my CJ is because of the cost to retube to make is a passenger drop). With an I6 and 33s the Dana 30 front will probably hold up just fine. I think you will be best to find a Explorer 8.8 with 4.10 & limited slip. Then just regear the front to match.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 11 Old 08-25-2013, 10:07 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
Ok thank you all the help is much appreciated
post #9 of 11 Old 08-25-2013, 10:08 PM Thread Starter
Wsigalet95
1988 TJ Wrangler
I know there is a few years of explorers that will work for me but us there a certain year that would be suggested?
post #10 of 11 Old 08-26-2013, 08:10 PM
underpowered
all in all, a simple re-tube is not as hard an many think. a well equipped home shop should be capable of such a task. we are prepping to re-tube a chevy 44 to drivers drop right now actually.
post #11 of 11 Old 08-26-2013, 08:51 PM
uberxj92
1992 XJ Cherokee
You can get the 8.8 in different gears. The LSD axles will have an "L" on the tag 3L73 for example. Get the disc brakes.
You can get a Dana 30 HP out of a zj that has ABS. Bigger ujoints and if you go with 3.73 gears you can match the 8.8.
This way you keep lug patterns matched to 5 on 4.5
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
