Alignment Specs For TJ With 4 inch Lift - JeepForum.com
post #1 of 7 Old 12-13-2012, 11:17 AM Thread Starter
02WranglerTJ
Anyone have a lifted TJ that has similar specs? I'm going to replace my steering box soon and recently did the above mentioned rough country lift and would like some feedback on alignment specs you have used. I don't have adjustable control arms. I know the factory specs aren't going to do me a whole lot of good.
02WranglerTJ is offline
post #2 of 7 Old 12-13-2012, 02:10 PM
biffgnar
biffgnar's Avatar
All you are going to be able to set is toe-in. Set it in 1/8".
Romney in 2020!
biffgnar is offline
post #3 of 7 Old 04-04-2013, 09:37 PM Thread Starter
02WranglerTJ
I did the alignment a while back now the steering seems really sloppy. Time for ball joints??
post #4 of 7 Old 04-05-2013, 12:00 PM
biffgnar
biffgnar's Avatar
Can't automatically assume that. Could be a lot of things. Don't just throw parts at it. Properly diagnose.
Romney in 2020!
biffgnar is offline
post #5 of 7 Old 04-05-2013, 12:25 PM
eduardostewart
make sure you get this done right. if you are uncertain with yourself get an alignment. i learned the hard way... your tires will get EATEN
eduardostewart is offline
post #6 of 7 Old 04-05-2013, 04:09 PM Thread Starter
02WranglerTJ
I'm upgrading to a heavy duty currie steering system soon so hopefully this will help a bit too.
post #7 of 7 Old 04-05-2013, 04:09 PM Thread Starter
02WranglerTJ
Then ill get another alignment.
