air temp sensor - JeepForum.com
post #1 of 6 Old 05-24-2012, 11:07 PM Thread Starter
25greenwrangler
air temp sensor
so I did the whole lack and ats cleaning and what a difference!! but after about an hour it went back to the way it was. anny ideas on what to do next? the ats was covered in this black sludge if that helps
why buy when you can build?
25greenwrangler is offline
post #2 of 6 Old 05-26-2012, 01:01 PM Thread Starter
25greenwrangler
idle air control and manifold temperature sensor called it the wrong thing
post #3 of 6 Old 05-26-2012, 10:33 PM
jnicewan
What kind of problem are you having? If I understand correctly you cleaned the IAC and IAT (idle air control valve, intake air temp sensor)? did you clean the passage for the IAC and did you clean the throttle body too? After doing that did you reset the PCM, or unplug the battery for a couple mins? Resetting PCM is usually a good idea because it lets the PCM relearn idle strategy.
jnicewan is offline
post #4 of 6 Old 05-28-2012, 09:59 PM Thread Starter
25greenwrangler
pour fuel economy hesitation and whenever I start kt after the first ten declines of running it almost stalls then comes back, cleaned the passages and reset the ecu by disconnecting the battery.plugs, wires are all good checked the D'OH! items. so far some of my interntet research seems to go with my theft
also did a test using a vom and it failed horebly
post #5 of 6 Old 05-28-2012, 10:00 PM Thread Starter
25greenwrangler
post #6 of 6 Old 06-03-2012, 07:16 PM Thread Starter
25greenwrangler
update:replaced the air temp sensor at a cost of 18 bucks, engine runs smoother but still lacks power,although power seems to come back the more I drive it(I only drove it 3 miles) oh and I unhooked the negative battery terminal for 10 minutes to reset the pcm andmy question is this since iv had this problem for 4 years, does it take pcm a long time to relearn with the right signals? or should it do that instantly? and as a bonus somehow the engine ticking is quieter.
tranny temp sensor richardclarkjr General Jeep & Off-Road Equipment 1 05-15-2012 02:31 PM
2000 xj temp sensor Supertrooper50 Engines & Drivetrain 0 04-11-2012 08:07 PM
temp sensor for tranny richardclarkjr Engines & Drivetrain 3 04-01-2012 12:56 AM
temp sensor for gauge, where is it? willyb8 Audio, CB & Ham Radios, GPS, & Electrical 3 03-04-2009 06:05 PM
coolant temp sensor teenwolf1393 Engines & Drivetrain 0 05-17-2007 02:36 AM
