Air in coolant 4.0 - JeepForum.com
post #1 of 3 Old 10-14-2007, 06:29 AM Thread Starter
TJW909
Air in coolant 4.0
Hey guys what is the trick to getting the air out of the coolant system on a 4.0. I had to change a leaking freeze plug and I can not get the system to take coolant? I done some checking on google and they say the 4.0's are famous for getting air in the head, but no luck on finding any info on purging the system???????
TJW909 is offline
post #2 of 3 Old 10-14-2007, 10:12 AM
crb577
fill the rad completely with coolant and run the jeep until the t stat opens you'll notice a drop in the coolant level and keep filling until you see no bubbles and a steady flow of coolant. that's what i did just kept adding you'll see the level drop every now and then just add to it.
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #3 of 3 Old 10-16-2007, 11:35 PM
89warwagon
1989 XJ Cherokee
On the back of the head(driver side)there is a sender screwed in for the temp gauge,loosen but don't remove it completely.Start engine and let it get up to operating temp....the air should seep past the threads because this is the highest point...... coolant starts dribbling out letting you know all the air has escaped.
One other thing that helps is to drill a 1/8" hole at 12 and 6 oclock position in the thermostat flange to help air escape(most t-stats have this already some dont)
89 xj 5.5 rubicon express,34" swamper ltb's
89warwagon is offline
401 Coolant In Oil Help.. RAHCORP Engines & Drivetrain 2 03-12-2011 03:37 PM
Coolant Amount mightywraps General Jeep & Off-Road Equipment 1 02-03-2009 05:07 AM
help 4.0 coolant and oil pressure Vassago Engines & Drivetrain 9 01-11-2009 08:14 PM
Leaking coolant solson96 Engines & Drivetrain 2 10-26-2008 06:37 PM
HARD coolant?! sean87xj Engines & Drivetrain 10 03-04-2006 04:07 PM
