Air conditioning year round? - JeepForum.com
post #1 of 18 Old 09-03-2013, 09:43 PM Thread Starter
Terry777
1997 XJ Cherokee
Hey all, I`m thinking of buying another belt and bypassing the air conditioner for the cooler months even though I`ve never used it I`m going to keep it incase I ever sell or want to turn it into an air source :/
Will I see gains in MPG and engine performance ? Will the compressor seize and be no good?
I park in an unground so no direct weather and the Vancouver lower main land is never that hot or cold so no problems there.
Thanks for your time.
Terry777 is offline
post #2 of 18 Old 09-04-2013, 07:32 AM
Holder350
1995 XJ Cherokee
With the system off (no ac or defrost on) the compressor is nothing more than an idler pulley.
You could unplug the clutch connection to keep the compressor from running even when you had the defrost on.
Besides on the 4.0 its impossible to bypass the AC without removing the compressor and adding a AC delete pulley.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 18 Old 09-04-2013, 01:02 PM Thread Starter
Terry777
1997 XJ Cherokee
Ok thanks, I`ll just unplug the clutch connection for the cooler months. cheers!
Terry777 is offline
post #4 of 18 Old 09-04-2013, 02:01 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
And then your defroster will work poorly.................
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 18 Old 09-04-2013, 03:48 PM
JeeperCreepers7
There's no need to do anything weird/special, when it's off it's off.
JeeperCreepers7 is offline
post #6 of 18 Old 09-04-2013, 04:56 PM
Holder350
1995 XJ Cherokee
True that. If my compressor worked I would much rather have it available to help defrost and defog the interior windows. Unless you turn the selector to defrost or AC the compressor will not be running.
Most people don't realize how much moisture the AC system removes from the cabin.
post #7 of 18 Old 09-04-2013, 08:15 PM Thread Starter
Terry777
1997 XJ Cherokee
So I`ll just leave it alone, It`s not charged and I have never needed it anyway I`m born and raised in Ontario so the Vancouver heat is a joke just like their winters...
I would rather keep the windows down & breath fresh air anyway, air conditioned vehicles always make me feel ill no matter how old or new.
Terry777 is offline
post #8 of 18 Old 09-04-2013, 08:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
If I wasn't confused before, I am now for sure.
post #9 of 18 Old 09-04-2013, 09:09 PM
Holder350
1995 XJ Cherokee
If the system is not charged the low pressure switch will not let the clutch engage.
So the system is not working and you don't plan to fix it you might as well make it into an OBA setup.
Sent from my phone
post #10 of 18 Old 09-04-2013, 09:51 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sent from my phone
Sooooo, it's not just me.
post #11 of 18 Old 09-04-2013, 10:33 PM
jjvw
jjvw's Avatar
Leave it alone for no other reason than having functional defrost. I was born and raised in Minnesota, so I appreciated AC in the miserable summers and defrosters in the bitter winters.
2003 Rubicon
jjvw is offline
post #12 of 18 Old 09-04-2013, 10:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
But his AC system is discharged.............
post #13 of 18 Old 09-04-2013, 10:50 PM
jjvw
jjvw's Avatar
I see that now..............7 posts in! Seems relevant to the original question.
2003 Rubicon
jjvw is offline
post #14 of 18 Old 09-04-2013, 11:43 PM
Holder350
1995 XJ Cherokee
One might think.....but none the less I hope his question was answered.
Kinda.
There was a question right?
Sent from my phone
post #15 of 18 Old 09-05-2013, 04:46 PM Thread Starter
Terry777
1997 XJ Cherokee
On board air ?
Kinda.
Sent from my phone
Yep, power theft from engine robbing MPG and it was mentioned it`s a free spinning wheel, with that said it`s still more belt and another wheel to turn but my non engineer`s out look is coming to the conclusion even a Dyno test would have trouble showing a difference
Thinking about the on board air but I have a nice little super flow MV-50 that's up to the task for my 265/75/16 = to 31.6X10.4.
That said could I use it without a tank or is the pressure not worth it?
Terry777 is offline
