Aftermarket 4.0L Exhaust Manifold that won't crack? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Aftermarket 4.0L Exhaust Manifold that won't crack?
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 07-16-2013, 12:12 AM   #1
2000NWXJ
I've seen all kinds of threads on cracked exhaust manifolds. What I want to know is the strongest replacement. I've heard that even the expensive-as-hell banks headers crack.
2000NWXJ is offline   Reply With Quote Quick reply to this message
Unread 07-16-2013, 06:46 AM   #2
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just make sure your engine and trans mounts are good and use a flex joint in your exhaust pipe where it crosses over uner the bell housing.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2013, 08:15 PM   #3
tcullen07
Looking into the same issue w my TJ right now. Ill let you know if I find a good set.
tcullen07 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2013, 08:36 PM   #4
figsmash
2003 WJ
I like to know of one to before I replace mine that is messed up I cant even find any aftermarket exhaust manifolds just the factory dorman for $200
figsmash is offline   Reply With Quote Quick reply to this message
Unread 07-17-2013, 08:47 PM   #5
tcullen07
Amazon and eBay have a few, but all have mixed reviews. And the rugged ridge one has mixed reviews. If I do the work, I don't want to do it again. I'd like to hear from someone about an aftermarket manifold that doesn't crack.
Unread 07-20-2013, 02:15 PM   #6
tcullen07
Talked to a mechanic out at Happy Trails 4x4 here in Jacksonville, FL, they specialize in Jeeps, and he said the best replacement for the exhaust manifold is the OEM replacement sold by Napa for around 200. He said Borla makes a sweet set that cost $800 if you want to throw your money away but avoid the cheap knock offs because you'll just be replacing the manifold again in 6 months.
Unread 07-20-2013, 02:49 PM   #7
DaemonForce
I'll settle for the stock 92 manifold. I really think flex pipe under the bell housing would significantly help too. There really aren't many options for aftermarket unless you like to patch stuff up with your own welds. I just don't have the equipment or patience.
DaemonForce is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 03:26 PM   #8
tcullen07
He did mention to look for the one with flex pipe. He said the ones at napa usually have it.
Unread 07-20-2013, 06:29 PM   #9
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sound advice here. ^^.
Unread 07-21-2013, 07:48 AM   #10
biffgnar
biffgnar's Avatar
Get one of the newer model TJ OEM two piece ones. OP, not sure if any option like that for XJs.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
4.0 , aftermarket , crack , exhaust manifold
