Aftermarket 4.0L Exhaust Manifold that won't crack? - JeepForum.com
post #1 of 10 Old 07-16-2013, 12:12 AM Thread Starter
2000NWXJ
I've seen all kinds of threads on cracked exhaust manifolds. What I want to know is the strongest replacement. I've heard that even the expensive-as-hell banks headers crack.
2000NWXJ is offline
post #2 of 10 Old 07-16-2013, 06:46 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just make sure your engine and trans mounts are good and use a flex joint in your exhaust pipe where it crosses over uner the bell housing.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 10 Old 07-17-2013, 08:15 PM
tcullen07
Looking into the same issue w my TJ right now. Ill let you know if I find a good set.
tcullen07 is offline
post #4 of 10 Old 07-17-2013, 08:36 PM
figsmash
2003 WJ
I like to know of one to before I replace mine that is messed up I cant even find any aftermarket exhaust manifolds just the factory dorman for $200
figsmash is offline
post #5 of 10 Old 07-17-2013, 08:47 PM
tcullen07
Amazon and eBay have a few, but all have mixed reviews. And the rugged ridge one has mixed reviews. If I do the work, I don't want to do it again. I'd like to hear from someone about an aftermarket manifold that doesn't crack.
post #6 of 10 Old 07-20-2013, 02:15 PM
tcullen07
Talked to a mechanic out at Happy Trails 4x4 here in Jacksonville, FL, they specialize in Jeeps, and he said the best replacement for the exhaust manifold is the OEM replacement sold by Napa for around 200. He said Borla makes a sweet set that cost $800 if you want to throw your money away but avoid the cheap knock offs because you'll just be replacing the manifold again in 6 months.
post #7 of 10 Old 07-20-2013, 02:49 PM
DaemonForce
I'll settle for the stock 92 manifold. I really think flex pipe under the bell housing would significantly help too. There really aren't many options for aftermarket unless you like to patch stuff up with your own welds. I just don't have the equipment or patience.
DaemonForce is offline
post #8 of 10 Old 07-20-2013, 03:26 PM
tcullen07
He did mention to look for the one with flex pipe. He said the ones at napa usually have it.
post #9 of 10 Old 07-20-2013, 06:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sound advice here. ^^.
post #10 of 10 Old 07-21-2013, 07:48 AM
biffgnar
biffgnar's Avatar
Get one of the newer model TJ OEM two piece ones. OP, not sure if any option like that for XJs.
Romney in 2020!
biffgnar is offline
4.0 , aftermarket , crack , exhaust manifold
