After resetting Check Engine Light, time till no more inc. - JeepForum.com
post #1 of 4 Old 09-12-2012, 04:09 PM Thread Starter
hbeach1
I have to reset my check engine light for an inspection and when they hook it up a lot of things still show incomplete. How many miles do you have to put on it after reset for it to calculate everything and say its alright so it will pass inspection? I sure do miss the days when this wasn't a problem. I forget computers are running the show now.
2001 Limited Edition Jeep Cherokee
hbeach1 is offline
post #2 of 4 Old 09-12-2012, 06:36 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I think you have to drive about 75 miles or so or have a few cold to hot run cycles before it is OK. What was the trouble code in the first place?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 4 Old 09-13-2012, 11:06 AM
mdm
Farm Wheeler
There has to be a number of cold start to warm cycles before it will indicate properly for inspection. Just driving around won't do it.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 4 Old 09-13-2012, 09:36 PM Thread Starter
hbeach1
Cylinder 3 was misfiring, but I replaced all the spark plugs and fixed it. Thank you for the knowledge, I was told it was just about the milage. Had no clue it was cold starts as well. Thanks again!!
hbeach1 is offline
check engine light , reset service indicator
Check Guages and Check Engine Light monto General Jeep & Off-Road Equipment 3 01-11-2013 10:04 AM
Engine Problems: overheating, check engine light jp1020 Engines & Drivetrain 0 04-29-2012 08:50 PM
check engine light stops engine trouble. Damnit94 Engines & Drivetrain 4 04-10-2012 07:13 PM
Check Engine Light hottie54rocker General Jeep & Off-Road Equipment 3 10-12-2010 11:17 PM
Check Engine Light hottie54rocker Audio, CB & Ham Radios, GPS, & Electrical 3 10-12-2010 08:33 PM
