advice on mods - JeepForum.com
post #1 of 2 Old 04-24-2004, 12:07 PM Thread Starter
lostinfl
advice on mods
Daily driver some lite offroad (but you never know Tellico is only 2 hrs away) 98TJ Would like some advise on some mods I am planning to do
1 Lift kit Am looking at either the RE7003 3.5 Skyjacker 4 in single flex or Teraflex kit. Are these ok for daily driving use? No body lift wanted.Will the t case drop kit be fine or do I need to go ahead with the SYE and new shaft.Probably will run no bigger than 33's for a while.It is a 3.73 gear with stock d35 and d30 diffs.
2 Already have AirMax kit with TB spacer.I read an article that said if you grind out the spirals and the throttle body top you see an increase of HP.Anyone tried it?
3.Looking at the Borlja cat back unless one of the others is better.
3. JET stage 2 chip with thermostat.
4. New coil,wires,plugs high output (any reccomendations accepted)
I want the HP and torque to offset the gearing for bigger tires that will come in the future if possible. Do not want to drop in the money if I am on the wrong track, I have read alot and you info has been good. I had an 81 CJ, was much different.
lostinfl is offline
post #2 of 2 Old 04-28-2004, 08:33 PM
mike5468
Don't go with the Skyjacker lift
Iv'e seen the Skyjacker lift on a 1987 Wrangler, on my last Jeep Jamboree & it wasn't a good thing.It dosent flex & and it over traveled and locked up the suspension. We had to leave the Jeep on the side.
mike5468 is offline
2.5 mods?? airdevil85 Cheap Tricks & Fixes 27 12-09-2012 10:46 PM
Might sell. Need advice regarding mods. HighRisk General Jeep & Off-Road Equipment 0 07-17-2009 10:54 AM
4.0L mods? shinigami Engines & Drivetrain 3 12-15-2006 06:02 AM
98' 5.9 mods bracket racer Engines & Drivetrain 2 11-17-2005 11:28 PM
advice on mods lostinfl Tires & Wheels 5 04-24-2004 09:27 PM
