Advice in axles needed - JeepForum.com
post #1 of 8 Old 10-25-2013, 07:51 AM Thread Starter
Luke95
For my xj I'm debating between a Dana 34
http://www.naxja.org/forum/showthread.php?t=1062525
Or an eb Dana 44 swap the axle is a 78 so it has the cast wedges. I like my 8.25 so I don't want to Change it. I really want hubs that's about it. I want to be able to also wheel my 34s no worries. And if I go bigger not to have to worry as well.
Dana 34 pros 1 keeps my axle as is no major modifications. Cons weak tubes and no gain in splines
Dana 44 pros bigger tubes better r&p strength. Better BJ's. matching gears
cons same u joints. I'd need to worry about limiting straps and bumps tops more than I already do. Fab work is needed. But it does seem like a good option!
Moot point ford radius arms
So I'd love a bit of input.
I <3 rockrash
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #2 of 8 Old 10-25-2013, 08:48 AM
Evildriver-3
You want to put the 44F in place of the 30F or a 44R in place of the 8.25R ?
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 8 Old 10-25-2013, 09:01 AM Thread Starter
Luke95
Debating doing a hybrid dana 30 or a Dana 44 front
I <3 rockrash
Luke95 is offline
post #4 of 8 Old 10-26-2013, 01:49 AM
uberxj92
1992 XJ Cherokee
I built a waggy 44 for the mj recovery project I have. Live it.
Have a ruby 44 in my beast xj on 35's. Its good.
Got a 30 HP with the Volvo LS in it in another xj on 33's. Still not sure I like it.
I'm confused on a Dana 34?
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #5 of 8 Old 10-26-2013, 07:42 AM Thread Starter
Luke95
A Dana 34 is dana 44 spindles on a Dana 30 running big Dana 44 brakes. It's a way to get hubs and better brakes.
I <3 rockrash
Luke95 is offline
post #6 of 8 Old 10-26-2013, 11:57 PM
uberxj92
1992 XJ Cherokee
Awesome. I like the sound of it.
uberxj92 is offline
post #7 of 8 Old 10-28-2013, 05:59 PM
BlueRubiconrich
I run a cut down Scout 2 Dana 44 front. bigger Ring and pinion and
30 spline axle shafts VS small R and P and 27 Spline.
Go get a Waggy 44 make sure you get the one that will go in a XJ-YJ
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #8 of 8 Old 10-28-2013, 06:03 PM Thread Starter
Luke95
I am most likely going eb 44 front just modifying the radius arms and saying my motto **** it run it! It will be better than a lp waggy and it will work with my rear axle quite well!
I <3 rockrash
Luke95 is offline
