Adjusting idle - JeepForum.com
post #1 of 7 Old 09-06-2012, 02:01 PM Thread Starter
maestro89
Adjusting idle
99 tj; I had a exhaust leak and I added a all in one gasket, my jeep mysteriously only had one on the intake.
All is well but now she idles high about 2k. What is the best way to adjust this? The butterfly valve off and adjust that upside down screw? Seems too complicated for just this.
Thanks!
maestro89 is offline
post #2 of 7 Old 09-06-2012, 02:31 PM
mdm
Farm Wheeler
You most likely have a leak in the intake on the new gasket. There is no idle adjustment on the TJ.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 7 Old 09-06-2012, 02:41 PM Thread Starter
maestro89
Can I diagnose that with carb cleaner or something? If so how should I fix that?
post #4 of 7 Old 09-06-2012, 04:00 PM
mdm
Farm Wheeler
Your idle was normal before? You removed the manifold, replaced the gasket, reinstalled the manifold, and now you have a high idle. The manifold isn't seated properly.
mdm is offline
post #5 of 7 Old 09-06-2012, 04:49 PM Thread Starter
maestro89
Yeah it was normal before, basically what you said. I guess I'll take it all off again tomorrow after work
post #6 of 7 Old 09-06-2012, 04:49 PM Thread Starter
maestro89
Thanks
post #7 of 7 Old 09-07-2012, 09:40 PM Thread Starter
maestro89
How do I know if it is seated correctly ?
