99 jeep won't shift out of park - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > 99 jeep won't shift out of park
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 06-25-2010, 10:51 AM   #1
barkinrududay
Hi, I have a 99 Jeep Cherokee Classic that will not shift out of park. The gear shifter doesn't move at all. When I have my foot on the brake the button in the shifter goes in but I cannot select any gear. When I start the engine I can hear a load vibration on my feet, like someone is hitting my floor pan with a rubber mallet.
barkinrududay is offline   Reply With Quote Quick reply to this message
Unread 06-25-2010, 02:16 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check the motor mounts and the transmission mount. If they have failed, the engine can move enough to bind up the the transmission selector. Inspect the transmission shift mechanism under the center console, make sure everything is connected and moves smoothly. Make sure the transfer case is properly engaged in 2wd. Remember, 4wd is for use on slippery surfaces only. Do not use 4x4 on dry pavement.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 06-28-2010, 07:24 AM   #3
mdm
Farm Wheeler
Originally Posted by barkinrududay View Post
...the button in the shifter goes in but I cannot select any gear. ...
Is the shift lever moving through the pattern but the transmission not going into any gear or does the lever not move at all?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 06-28-2010, 07:26 AM   #4
TMar
Sounds like a mount.
Flickr
TMar is offline   Reply With Quote Quick reply to this message
stuck in park , no shift from park
