99 jeep won't shift out of park - JeepForum.com
post #1 of 4 Old 06-25-2010, 09:51 AM Thread Starter
barkinrududay
Hi, I have a 99 Jeep Cherokee Classic that will not shift out of park. The gear shifter doesn't move at all. When I have my foot on the brake the button in the shifter goes in but I cannot select any gear. When I start the engine I can hear a load vibration on my feet, like someone is hitting my floor pan with a rubber mallet.
barkinrududay is offline
post #2 of 4 Old 06-25-2010, 01:16 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Check the motor mounts and the transmission mount. If they have failed, the engine can move enough to bind up the the transmission selector. Inspect the transmission shift mechanism under the center console, make sure everything is connected and moves smoothly. Make sure the transfer case is properly engaged in 2wd. Remember, 4wd is for use on slippery surfaces only. Do not use 4x4 on dry pavement.
CJ7-Tim is offline
post #3 of 4 Old 06-28-2010, 06:24 AM
mdm
Farm Wheeler
Originally Posted by barkinrududay View Post
...the button in the shifter goes in but I cannot select any gear. ...
Is the shift lever moving through the pattern but the transmission not going into any gear or does the lever not move at all?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #4 of 4 Old 06-28-2010, 06:26 AM
TMar
Sounds like a mount.
TMar is offline
stuck in park , no shift from park
Jeep w/175,000 miles won't shift into gear rdepetris Engines & Drivetrain 0 05-05-2009 11:39 AM
Jeep Offroad Lights used in Jurassic Park? SRVLenny General Jeep & Off-Road Equipment 12 03-13-2009 10:28 AM
Jeep Stuck In Park vunit291 General Jeep & Off-Road Equipment 9 12-12-2008 01:05 PM
Won't shift to park InfantryWS6 Engines & Drivetrain 1 01-02-2007 09:59 PM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
