99 4.0 - Low Pressure and knock - JeepForum.com
post #1 of 8 Old 06-24-2013, 07:51 AM Thread Starter
AWheeler
I have read several threads about this issue, but have not found a similar situation yet...
I was wheelin' over the weekend and had a ball. Ran for about 3 hours in the AM. No issues and everything worked very well. It was warm outside, about 90 or so. Took the Jeep back to camp and had lunch for about an hour. After getting back from lunch, I started the Jeep and hear a ticking / knock sound. Opened the hood and it was coming from the fuel runners / exhaust manifold. So, I immediately thought I had a cracked manifold. The sound kept pace with the RPM's. So, I shut it off, looked under the hood for a minute, then started back up. It made the same noise for about 15 seconds, then went away. Has not made the sound sense. I did notice that while creeping on the trail, the oil pressure got low. At idle, it kept 15 - 20 psi, which is low to me, but OK.
What could this be? I have 145k miles on the motor, so should I go to something like 10w40 or 10w50? I use 5w30 right now.
Thanks all!
AWheeler is offline
post #2 of 8 Old 06-24-2013, 02:36 PM
GilaMtnJeep
GilaMtnJeep's Avatar
5w-30 is too light. IIRC proper oil viscosity is either 10w-30 or 10w-40.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 8 Old 06-24-2013, 02:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What brand of oil filter are you using?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 8 Old 06-24-2013, 02:41 PM
tinktinkTJ
10w-30 is the proper viscosity. Try changing the oil and see if that helps. I do run 5w-30 in the winter but I wouldn't run it in the summer.
tinktinkTJ is offline
post #5 of 8 Old 06-24-2013, 03:49 PM
GilaMtnJeep
Wyx
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
post #6 of 8 Old 06-24-2013, 05:30 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Originally Posted by FernBchJeep View Post
Wyx
LOL. I meant the OP. I figured you ran a good filter.
post #7 of 8 Old 06-26-2013, 08:36 PM
esiegler3
Change the oil pump, I'm doing my pump this weekend to a high output pump. I have the same problem no pressure.
esiegler3 is offline
post #8 of 8 Old 07-04-2013, 02:59 PM Thread Starter
AWheeler
ProMotive (Purolator). Sorry for the delayed response...
I have put a few hundred more miles on it and it has not done it since.
AWheeler is offline
